I am putting together a proxy/firewall config ... and I want to pass this by the pros to make sure I have this correct (this is my first shot at something like this) ... and for suggestions/answers.
1: Proxy: Windows 2003 Web Edition running Apache 2.0 will act as a reverse proxy with 2 IP's (NIC1 with 2 IPs assigned via IP aliasing) in front of the FW.
2: Checkpoint Firewall.
3: 2 Windows 2003 Web Edition HTTP servers behind the FW
Two domains with SSL Certs will be hosted on the proxy in the DMZ: NIC1 is connected to the ISP
So:
PUBLIC IP1:443
5000 --> INTERNAL IP1:80 PUBLIC IP2:443
5001 --> INTERNAL IP2:80
Site "One": Proxy will fwd requests from "one:443" to "Firewall IP Port 5000". Firewall will fwd requests from "Firewall IP Port 5000" to "Internal IP1:80".
Site "Two": Proxy will fwd requests from "two:443" to "Firewall IP Port 5001". Firewall will fwd requests from "Firewall IP Port 5001" to "Internal IP2:80".
Three Question:
1: Does this look correct? Any errors?Am I close?
2: Do I need to setup some sort of routing on the Proxy to route traffic from NIC1 to NIC2?
3: I am not sure how the IP's should be config'd between the proxy and the FW:
Proxy NIC 1 is easy since that is obviously the ISP IP config, and the internal net I can make whatever I need it to be. So what would the IP/Gateway/Netmask config be for Proxy NIC2 and the FW DMZ NIC?
Thanks.
