Basic NAT question
Dec 16, 2005 1 Replies
Hello,
Is it possible to configure NAT as static many-to-one where the "many" side is always the same and so is the "one" address? If so how often is type of NAT used?
I also have the same question when it comes to dynamic NAT?
Thanks Anund
Sure. Anyone who uses private, static addresses does this. I do on my network. On the private side of the firewall the computers are assigned a static IP from 192.168.1.x and they all are NATed to my single public static IP address on the other side of the firewall.
This is also quite common. Many people use DHCP to assign a dynamic private address to their systems and then NAT them to either a single address on the public-facing side of the firewall, or to a range of addresses (this is called a "DIP" in the Netscreen world).
