3015 Concentrator Private Interface Gateway
Jun 28, 2007 1 Replies
How do you set the default gateway for the private interface? How do you set the default gateway for vpn client connections? I have configured the device and created a group and internal user authentication. I can authenticate and connect. However I can't browse the Web because the default gateway on the vpnclient using cisco vpn client 4.8 shows it is the same as the ip address it obtains instead of the network default gateway.
Do I have to enable split tunneling in order to browse the web when connecting via cisco vpn client?
Steve
you should either browse the internet through your vpn connection and you have to make sure that you have setup properly the "tunnel default gateway" in the routing options of the vpn concentrator, or you have to do split tunneling.
