Cisco PIX 515E RDP and Printing question...
Jan 19, 2006 4 Replies
Jump to replies (4)
I have a vpn set up on my cisco pix 515e. The users can log on and work fine. I have it set up so that they can access their LAN while they are connected to the vpn.
Here is the problem: There is a network printer in a office that is connecting to the vpn and remote desktop. I have set up the computer that needs to print in their office so that it thinks the printer is on the LPT3 port instead of being a network printer. I used the 'net use' command and installed the driver on the LPT3 port.
They can see the printer when they are in remote desktop, but they are unable to print. It just sits there, and nothing comes out of the printer. Nothing goes into the que either for that printer. I can watch as the user logs into the Terminal Services server, and i can see their printer, and that they have full permission.
PLEASE HELP.
Thanks Jason
Also, i have split tunneling set up, but when i go to the client, and look at the routes, i only see 192.168.0.0 255.255.255.0 route. I don't think that every office that is connecting is on this subnet. do i need to add additional split tunneling routes? And if so, how?
Thanks Jason
This is more of a Microsoft RDP problem than a network issue. I am not sure but in terminal services configuration mode you can allow local ports and inversely not allow local ports. Local ports in this case being COM1, LPT1, etc. You could start by ensuring that those are allowed in the RDP session.
I had this going fine until we installed the PIX515E. All of the RDP settings are good to go. All of the necessary port are being forwarded for printing. Like i said, they can see their printer when they log on, but it will not print.
It was working fine until we installed the PIX. Any ideas?
Thanks Jason
You say the problem started with the PIX, but did you introduce VPNs with the PIX? Are the VPN tunnels terminating on the PIX? How did you configure the PIX VPN tunnels?
