two networks
Dec 05, 2006 2 Replies
two networks open original image
Want to setup two separate netwoks in lab, and test voip calls between them. How to configure both netwoks to call each other and type of routers to be used. thanks
You have to be more specific.
- What type of VoIP do you want to test? Cisco Callmanager (Express)? Asterisk? Other?
- Are you starting from scratch or do you have some hardware?
- Do you want to simulate VoIP between 2 sites across WAN?
Start here:
Hi
You should have two two machines and routing device inbetween with voip enabled in lab.
Machine1 - Router - Machine2 ip/24 ip/16
What voip box or callmanger or VOIP Call Software server according to your need what you want to use?
CK
v wrote:
