What happen if i take a switch over satellite to do a satellite -lan? What are th problems?
switches and satellite
Sep 25, 2004
Most relevant reply
A satellite lan? Can you be more specific? If you mean you are trying to create a lan and have all computers on it access internet via satellite, then its doable. If the satellite uses ethernet, then you can get a cable/dsl router to share the internet connection. If it uses…
If it uses USB, which is what Directway used last time I checked (3 years ago) then you will need one computer on the lan with 2 NICs and setup Internet Connection Sharing(if using Windows).
The only problems I see, ......satellite internet stinks. Its an ok concept, but the latency will have you pulling your hair out. Dial-up is almost better, but not for downloads.
