If you can take a look at back of the motherboard, look for an over-sized phone jack. That would be the Ethernet port. (:
-mike
If you can take a look at back of the motherboard, look for an over-sized phone jack. That would be the Ethernet port. (: -mike
-mike
Yes.
Regards
Bill
Does the Lan socket on my computer mean that my computer has Ethernet. The motherboard manual says it has a Build-in RTL8100L Chipset (On-Board LAN).
Regards Brian
