Did ECS K8M800M2's onboard network die?
Dec 02, 2005 21 Replies
We don't remember since it was done like about five years ago. My friend thinks it was "-B". Is there a way to check? Any photographs to show so I can check? I hope they are distinguishable.
Weird, the last two overnights (10 hours), no problems. This is before the first disconnection and having to power off the machine completely to reset the network. I turn the machines off when I am at work (14 hours or so).
Any photographs of this so I can compare? I am pretty sure the cables are fine other computer and network cards do not have problems. Only this specific motherboard's onboard network has this problem.
They are very distinguishable, but it doesn't matter
-- both are good, but precious little else is.
Sure. Search the web.
This is an intermittant problem. Very typical of split pairs. Also typical of solid-conductor patchcords.
-- Robert
