[X-post] Better AES software or 3DES hardware?
May 08, 2005 2 Replies
Walter Roberson
:On a 837 doing only one VPN to headquarter is better using AES via software or 3DES via hardware :accelerator? I heard AES is quite faster rather then 3DES. 3DES. Mbps 3DES, 2 Mbps AES-128
[X-post] Better AES software or 3DES hardware? open original image
3DES via hardware accelerator? I heard AES is quite faster rather then 3DES.
Thanks,
Alex.
In article , AM wrote: :On a 837 doing only one VPN to headquarter is better using AES via software or
3DES.
7 Mbps 3DES, 2 Mbps AES-128
I have some concerns regarding 837 crypto performance however I have not proved the issue by any means.
In summary I seem to see consistent drops at the rate of about
1 in 1000 over the VPN. One end is 837 and the other end is firewall 1.
There are some numbers reported by the 837
router#sh cry eng acc stat .... 3061179 packets in 3061179 packets out tx_lo_count 2833
router#sh proc cpu | inc cry PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 140 575164 2720 211457 0.00% 0.05% 1.09% 0 crypto sw pk pro router#
This process runs for 211457 micro seconds at each invocation which is an eterntiy in CPU terms.
More details in thread "IOS Crypto drops" March 15 2005 in this group.
