WS-C2924-XL-EN switch
Feb 09, 2006 3 Replies
Jump to replies (3)
This is an old cisco switch, it's running ver 11.2(8.1)SA6. I have it configured wuith (4) vlans for my home network. I know that the access to the switch is from vlan 1. Can this be changed to a different vlan???
Thanks
# conf t (config)# int vlan (config-subif)# management
B
Say if you want it to be change to vlan 5 for example:
conf t int vlan 1 shut int vlan 5 ip addre "vlan-5-ip-address" "vlan5-subnet-mask" no shut ip default-gateway "vlan-5-default-gateway" end wr
That should do the job Horst
Thanks
Seems like this newsgroup was down for a few days with my isp.
