VoIP (SIP) though an Soho91
Oct 18, 2005 0 Replies
Hello !
I have actually a config-problem which starts to drive me crazy :
I simply try to use an VoIP client though my Soho91 . The config of the Client seems OK, it works when I use an different DLS router (a standard home-solution) without any special settings on it.
Now i try the same using my Cisco It seems that the INVITE-message is sent, authentication at the SIP-proxy works. I even get back an answer from the SIP-Proxy (something like 'your call is important to us ......') but then I get an timeout error.
I allready disabled everything regarding firewall (enabling this raises the trouble - even if all neccessary ports should be open).
As I said, using an 'cheapo' DLS-router everything works fine.
Any ideas where to search for the problem ?
Carsten
