Winproxy behind router
Aug 07, 2007 0 Replies
I've recently set up Winproxy on a small network for a client of mine because they were looking for an inexpensive solution to control Internet access. Currently have it set up on a machine using two nic cards as required. Both internal and external nic cards are actually connected the LAN side of a Linksys hub/router and the DSL modem is of course going into the WAN side of the router. The reason I did not connect the external nic directly to the DSL modem as would be normally done with a proxy is that we have a couple of machines that we want to bypass the proxy server and go direct. Now the Linksys router is handling DHCP for the entire network so I disabled Winproxys DHCP server. Here are the settings of everything:
Proxy Server Internal Card (Connected to LAN port on Linksys router) IP:192.168.1.15 SM: 255.255.255.0 No gateway assigned PDNS: 192.168.1.103 SDNS: 192.168.1.1
Proxy Server External Card (Connected to LAN port on Linksys router) IP: 192.168.1.16 SM: 255.255.255.0 GW: 192.168.1.1 PDNS: 192.168.1.1 SDNS: 192.168.1.1
Client cards: IP: 192.168.1.100 SM: 255.255.255.0 GW: 192.168.1.15 PDNS: 192.168.1.103 SDNS: 192.168.1.1
Set up the way I have it now it seems to be causing a problem where the proxy machine cannot see the network. Cannot access or even ping any IP's on the network at all and yet the network clients have no problem seeing and pinging proxy server. I suspect this may be related to both the proxy servers NIC's both being on the same subnet which is normally not correct when setting up a Winproxy machine. Since both NIC's of the proxy server are connected to the same router and thus on the same subnet can I still change the IP of the external card to a different subnet such as 192.168.2.16 even though its connected to the same subnet as as the internal card. The external card only needs to grab internet access for Winproxy from the router. It does not need to see the network for anything else. Thats the job of the internal card.
Thanks in advance, Adam
