TACACS problem
Jul 26, 2006 3 Replies
Jump to replies (3)
Hi would really appreciate if anyone could make any suggestions on an error I am seeing on my test switch regardings a new TACACS + server I have just built. Here is the config on the switch:-
aaa new-model aaa authentication login default group tacacs+ local enable aaa authentication login vtymethod group tacacs+ enable aaa authorization exec default group tacacs+ local none aaa authorization commands 0 default group tacacs+ local none aaa authorization commands 1 default group tacacs+ local none aaa authorization commands 15 default group tacacs+ local none aaa accounting commands 15 default start-stop group tacacs+
tacacs-server host 192.168.112.100 tacacs-server key xxxxxxxxxx
When I run a debug aaa authentuication on the switch I get the following error message.
16:52:21: AAA: parse name=tty2 idb type=-1 tty=-1
16:52:21: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
16:52:21: AAA/MEMORY: create_user (0x80CF57A4) user='' ruser='' port='tty2' rem_addr='172.16.11.211' authen_type=ASCII service=LOGIN priv=1
16:52:21: AAA/AUTHEN/START (4186451996): port='tty2' list='' action=LOGIN service=LOGIN
16:52:21: AAA/AUTHEN/START (4186451996): using "default" list
16:52:21: AAA/AUTHEN/START (4186451996): Method=tacacs+ (tacacs+)
16:52:21: TAC+: send AUTHEN/START packet ver=192 id=4186451996
16:52:22: AAA/AUTHEN (4186451996): status = ERROR ********** PROBLEM HERE******
16:52:22: AAA/AUTHEN/START (4186451996): Method=LOCAL
16:52:22: AAA/AUTHEN (4186451996): status = GETUSER
16:52:52: AAA/AUTHEN/ABORT: (4186451996) because CTRL-C pressed.
16:52:54: AAA/MEMORY: free_user (0x80CF57A4) user='' ruser='' port='tty2' rem_addr='172.16.11.211' authen_type=ASCII service=LOGIN priv=1
Gazza,
may be "debug tacacs" digs up a bit more.
Rainer
Thanks I found the problem was with the tacacs.conf file. I had put in a typo.. now works OK however I can't stop it dropping straight into enable mode. I want it to prompt for an enable password still, any more ideas ?
Ra> > When I run a debug aaa authentuication on the switch I get the
Gazza,
i didn't use tacacs for this so far ... but if users are configured locally ... like ...
user USERNAME priv xx pass 0 pass
... may be there is an equivalent to this "priv xx" in your tacacs-config.
Rainer
