tacacs and 2950
Jan 16, 2006 5 Replies
Jump to replies (5)
I cannot get the tacacs authentication to work on our 2950's. I have it working on 3750's and other various swithes. The commands that I have entered on the tacacs side are:
aaa new-model aaa authentication login MYGROUP group tacacs+ local line enable aaa authentication enable default group tacacs+ enable
tacacs-server host 10.29.2.32 key dingdong123
line vty 0 4 exec-timeout 15 0 logging synchronous login authentication MYGROUP length 0 transport input telnet
username joesmith privilege 15 secret 5 whateverlistedhere
I have listed the commands that are part of the tacacs config I am using.
I appreciate your help...
thx Bran
your config looks good.
does the tacacs server show authentication attempt. any reasons for authentication failure ?
OR else you see authentication debugs and see if the tacacs server is reachable and if it is returning "FAIL"
Can you ping the TACACS server from the box ? maybe you have forgot a def gateway or something, or a source interface statement.
just for kicks: Have you tried the tacacs-server key
command aswell ?
Just as a test I created another account in active directory and that one worked. They both use the same password and are not disabled in AD all seems well. Can an account be corrupt? restart tacacs server service etc. Any thoughts on that one?
