Symbol wireless controller
Aug 18, 2006 3 Replies
Jump to replies (3)
Do anyone got any knowledge of Symbol & how they fare in marketplace vis-a-vis other more well-known players ?
You may wish to investigate Symbol vs. Cisco competitve comparisons.
Symbol WS 5000 Switch
vs.
Cisco Aironet 1220:
also this White Paper:
Hope this helps.
Brad Reese Cisco vs. Competitor Lab Tests
Thanks for the prompt reply. This report is comparing Symbol thin AP client technology with Cisco thick AP client (not apple to apple comparison). Cisco has acquired Airespace. Is there a comparison report of Symbol thin AP client technology with Cisco Airespace thin client technology.
The report is quite old. Any newer ones.
Thanks
wrote:
No, just an Aruba 5000 WLAN Security System vs. Cisco Airespace 4012 WLAN Switch:
and the Cisco Airespace 4000 Wireless Switch / Airespace 1200 Access Point Evaluation:
Sincerely,
Brad Reese Cisco Power Supply Headquarters
