Strange MPLS Connectivity Problem
Jan 31, 2006 1 Replies
All,
I have been implementing an MPLS connection (1Mb link). The config on the serial end uses frame-relay encapsulation. (IETF encapsulation with Cisco LMI, DLCI 16)
My serial shows up/down indicating layer 2 problems. When plugging a hard loopback plug on the NTU the carrier can ping their IP successfully (they sent me the results). When I install my X.21 cable I get no joy.
We built a template for the MPLS sites as there are a number to install. I know the template is good as other sites have been installed successfully. I spoke to the Telco to go through the config and the frame-relay encapsulation, LMI and DLCI info all match. The IP address on the WAN is correct.
When doing a show frame-relay pvc the PVC status show deleted. How can this be if the testing to the NTU is successful. One would assume I guess it's the connection between the NTU and router, however, I have tried 2 x separate routers, 2 x separate WIC cards and 2 x separate X.21 cables. The IOS is standard across all sites. 1 x router was the existing site router that I re-configured so I know it was working.
Anyone any ideas why the line protocol may be down.
I'm stumped !!
Regards
Darren
You said that Telco can ping the NTU. When you say ping you are referring to ICMP layer 3. The NTU would be Telco side. Sometimes when telco sends a loopback that can bring the circuit or PVC up or active. So the pings would be suceesfull. i am also doing a MPLS migration. We went from frame -relay to PPP during our migration. PPP encap removes lteh frame switch so lantency is removed.
A PVC showing deleted indicates that the frame switch ha slost the PVC config.
Chanves are they have your DLCI pointing wrong!
