spurious DMZ
Jan 31, 2006 1 Replies
Confused by portions of the config file (see below). I set up this Pix, and serviced it yesterday,
but dont have full responsibility for it.
I see that an object group has a network object refering to non existant DMZ addresses:
network-object 192.168.2.10 255.255.255.255
used again in a static:
static (inside,dmz) 192.168.2.10 XXXXXXX1 netmask 255.255.255.255 0 0
I was told this allowed for communication between servers in the inside and the DMZ.
I half expected to find multiple IP's on the servers in both the 192.168.0 and 192.168.2
but didn't. (Walter , what do you think ?)
: Saved
: Written by enable_15 at 15:21:06.511 UTC Mon Jan 30 2006
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password Rxxxxxxxxxxxx encrypted
passwd xxxxxxxxxx encrypted
hostname atcentralfw
domain-name atcentral
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
name 192.168.0.101 XXXXXXX1
name 192.168.0.102 XXXXXXX2
name 192.168.0.112 XXXXXXXf2
name 192.168.0.111 XXXXXXXf1
name 192.168.2.121 XXXXXXXweb
name 192.168.0.103 XXXXXXX3
name 192.168.0.104 XXXXXXX4
object-group service XXXXXXX tcp
port-object range 6990 6992
object-group network XXXXXXXServers
network-object XXXXXXX1 255.255.255.255
network-object XXXXXXX2 255.255.255.255
network-object XXXXXXX3 255.255.255.255
network-object XXXXXXX4 255.255.255.255
object-group network XXXXXXXServers_ref
network-object 192.168.2.11 255.255.255.255
network-object 192.168.2.12 255.255.255.255
network-object 192.168.2.13 255.255.255.255
object-group service PCAnywhere tcp-udp
description PCAnywhere Standard Ports
port-object range 5631 5632
object-group service PCAnyWeb tcp-udp
description PCAnywhere and Web Services
port-object range 80 80
access-list inside_outbound_nat0_acl permit ip any 192.168.0.192
255.255.255.192
access-list outside_access_in permit tcp any interface outside object-group PCAnyWeb
access-list outside_access_in permit icmp any any echo
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit tcp any host 192.168.0.42 range 10000
10005
access-list outside_access_in permit tcp any host 192.168.0.122
access-list outside_access_in permit udp any host 192.168.0.122
access-list outside_access_in permit tcp any interface outside range 3060
3064
access-list outside_access_in permit udp any interface outside range 3060
3064
access-list dmz_access_in permit tcp host XXXXXXXweb object-group XXXXXXXServers_ref object-group XXXXXXX
pager lines 24
logging timestamp
logging monitor debugging
logging trap debugging
logging host inside 192.168.0.244
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside XXX.XXX.XX.1XX 255.255.255.252
ip address inside 192.168.0.2 255.255.255.0
ip address dmz 192.168.2.1 255.255.255.0
ip verify reverse-path interface outside
ip audit name checkit attack action alarm reset
ip audit interface outside checkit
ip audit info action alarm
ip audit attack action alarm
ip local pool XXXdsupport 192.168.0.200-192.168.0.230
pdm location 192.168.0.31 255.255.255.255 inside
pdm location XXXXXXXf1 255.255.255.255 inside
pdm location 192.168.2.33 255.255.255.255 inside
pdm location XXXXXXXweb 255.255.255.255 dmz
pdm location XXXXXXX1 255.255.255.255 inside
pdm location XXXXXXX2 255.255.255.255 inside
pdm location XXXXXXXf2 255.255.255.255 inside
pdm location 0.0.0.0 255.255.255.255 inside
pdm location 192.168.2.10 255.255.255.255 dmz
pdm location 192.168.2.11 255.255.255.255 dmz
pdm group XXXXXXXServers inside
pdm group XXXXXXXServers_ref dmz reference XXXXXXXServers
pdm history enable
arp timeout 14400
global (outside) 1 interface
global (dmz) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (dmz,outside) tcp interface www XXXXXXXweb www netmask
255.255.255.255 0 0
static (dmz,outside) tcp interface pcanywhere-data XXXXXXXweb pcanywhere-data netmask 255.255.255.255 0 0
static (dmz,outside) tcp interface 5632 XXXXXXXweb 5632 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 10000 192.168.0.42 10000 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 10001 192.168.0.42 10001 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 10002 192.168.0.42 10002 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 10003 192.168.0.42 10003 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 3060 192.168.0.122 3060 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 3061 192.168.0.122 3061 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 3062 192.168.0.122 3062 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 3063 192.168.0.122 3063 netmask
255.255.255.255 0 0
static (inside,outside) tcp interface 3064 192.168.0.122 3064 netmask
255.255.255.255 0 0
static (inside,outside) udp interface 3061 192.168.0.122 3061 netmask
255.255.255.255 0 0
static (inside,outside) udp interface 3060 192.168.0.122 3060 netmask
255.255.255.255 0 0
static (inside,outside) udp interface 3062 192.168.0.122 3062 netmask
255.255.255.255 0 0
static (inside,outside) udp interface 3063 192.168.0.122 3063 netmask
255.255.255.255 0 0
static (inside,outside) udp interface 3064 192.168.0.122 3064 netmask
255.255.255.255 0 0
static (inside,dmz) 192.168.2.11 XXXXXXX2 netmask 255.255.255.255 0 0
static (dmz,inside) 192.168.0.121 XXXXXXXweb netmask 255.255.255.255 0 0
static (inside,dmz) 192.168.2.12 XXXXXXX3 netmask 255.255.255.255 0 0
static (inside,dmz) 192.168.2.13 XXXXXXX4 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 155.212.99.141 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.0.31 255.255.255.255 inside
http XXXXXXXf1 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-pptp
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 33
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 20
console timeout 0
vpdn group PPTP-VPDN-GROUP accept dialin pptp
vpdn group PPTP-VPDN-GROUP ppp authentication chap
vpdn group PPTP-VPDN-GROUP client configuration address local xxxxxsupport
vpdn group PPTP-VPDN-GROUP client configuration dns xxx.xx.xx.2 xxx.xx.xx.15
vpdn group PPTP-VPDN-GROUP pptp echo 60
vpdn group PPTP-VPDN-GROUP client authentication local
vpdn username xxxxtech password xxxxxxx
vpdn enable outside
username dealer password XXXXXXXXXX encrypted privilege 2
terminal width 80
Cryptochecksum:XXXXXXXXXX
: end
In article , Barrett Bonden wrote: :Confused by portions of the config file (see below). I set up this Pix, and :serviced it yesterday, :but dont have full responsibility for it.
:I see that an object group has a network object refering to non existant DMZ :addresses:
:network-object 192.168.2.10 255.255.255.255 :used again in a static:
:static (inside,dmz) 192.168.2.10 XXXXXXX1 netmask 255.255.255.255 0 0
:I was told this allowed for communication between servers in the inside and :the DMZ.
That part's okay. When a host in the dmz addresses a packet to
192.168.2.10 then the PIX will proxy-arp the IP, accept the packet, and translate the destination to XXXXXXX1. Conversely, if XXXXXXX1 sends to the dmz, the dmz destination will see the source as 192.168.2.10.
I have not yet found a situation in which such a configuration has meaningful advantages over, e.g.,
static (inside,dmz) XXXXXXXX1 XXXXXXXX1 netmask 255.255.255.255 0 0
or the nat 0 access-list equivilent. I suppose there -is- the point that this configuration does not require that the DMZ hosts have any routing entries other than to their local subnet... and if there is no default route for them then there is a much lowered risk that the dmz hosts will accidently leak a packet outward.
There is a completely different section of your configuration which is broken:
Well, there is the point that you are using a PIX version with known security holes. You really should get the free security upgrades to 6.3(4).
That's not going to work. Your vpdn pool ip addresses are in the same subnet that belongs to the inside interface. When an inside host attempts to reply to an IP in the PPTP allocation range, the PIX is going to see that the IP coming in to the inside interface belongs to the inside interface subnet, and the PIX will drop the packet because PIX 6.x is designed to never route a packet in a [logical] interface and back out the same [logical] interface.
You need to change your XXXdsupport pool to reflect IPs in an unused range, such as 192.168.3.200-192.168.3.230 and then change your inside_outbound_nat0_acl so that the appropriate subnet appears in the destination field. When you have that set up, then as far as the inside hosts (and the PIX) are concerned, the
192.168.3.x destinations are "outside" [because of the default route] so the PIX will process NAT for them as appropriate for inside->outside transactions [which will be no NAT because of your nat 0 access-list], and the PIX will then match the translated IPs against the VPN tunnels it knows about and do the appropriate encapsulation and send to the appropriate public IP corresponding to that tunnel's public endpoint.
