interfaces on pix501
Jul 28, 2007 2 Replies
I have the pix 501, and am wondering if it's capable of providing more than two interfaces which, as I understand, I need.
I currently have configured an outside if (wan), and an inside on
192.168.1.1. I want to add a dmz but, it seems this model only accepts two interfaces. Is this correct? I'm using the applet browser configuration tool.
I'm trying to figure out how to add the following 3 interfaces on my network. inside - 192.168.1.1 management - 192.168.2.1 dmz - 192.168.3.1
Any help much appreciated.
"sh ver" shows: Cisco PIX Firewall Version 6.3(5)125 Hardware: PIX-501, 16 MB RAM, CPU Am5x86 133 MHz Licensed Features: Failover: Disabled VPN-DES: Enabled VPN-3DES-AES: Enabled Maximum Physical Interfaces: 2 Maximum Interfaces: 2
so I guess the answer would be "NO"
Roman Nakhmanson
Not possible with PIX 501
Physical Specifications
Dimensions and Weight Specifications Dimensions (H x W x D): 1.0 x 6.25 x 5.5 in. (2.54 x 15.875 x 13.97 cm) Weight: 0.75 lb (0.34 kg)
Interfaces Console Port: RS-232, 9600 bps, RJ-45 Outside: Integrated 10/100 Fast Ethernet port, auto-negotiate (half/ full duplex), RJ-45 Inside: Integrated auto-sensing, auto-MDIX 4-port 10/100 Fast Ethernet switch, RJ-45
