Sniffer?
Jun 17, 2007 1 Replies
Trendkill
Ethereal has a great freeware sniffer. Only problem will be if they are encrypted, but you should still be able to tell source/destination and ports, which is enough for a good first start. Just span the port to one or the other to a capture port with a workstation running…
I need to find out why certain packets are forwarded by the pix to the VPN, and why some are not. Any one recommends a specific software based tool?
Ethereal has a great freeware sniffer. Only problem will be if they are encrypted, but you should still be able to tell source/destination and ports, which is enough for a good first start. Just span the port to one or the other to a capture port with a workstation running ethereal. Unless of course you have 6500s and some NAMs.
