Site to Site 837
Nov 10, 2005 2 Replies
Typically this means that you'll be hooking the routers up back to back?
That can't be done with an ADSL product, they have to be hooked up through an ISP/telco with a central office DSLAM. You could route VPN traffic over the two ISP connections with the 837 though.
The VPN setup is your best solution unless you have more details.
Have a look at the following document on cisco.com
it gives a good explanation on what you need to setup a site-to-site vpn.
Regards. Erik
