Simple question
Jun 30, 2005 2 Replies
Hi, This may be a simple question, but I can't find it in my documentation!
How do I remove or delete a static route from my 837?
Regards SW
! conf t no ip route 'ip address' ' subnet mask' 'next hop or interface' end !
Thank you kindly. I knew it would be simple, I tried adding delete or remove at the end of the ip route command, but its even simpler than that! Regards SW
