Simple QoS Policy On 877
Oct 24, 2008 0 Replies
I have a simple qos policy that has 2 x class-maps for traffic differentiation, call them Fred and Ginger.
The class-maps call 2 x access lists say 100 & 101. In each there are a couple of entries for source and destination traffic, so far so good.
I assign the class maps to a policy map as such:
policy-map cpe-to-pe class Fred set ip dscp ef class Ginger set ip prec 2 class class-default fair-queue
I assign said policy to my ATM PVC.
int atm0 pvc 0/38 service-policy output cpe-to-pe
When testing I see values for my 'offered rates' & matches on the QoS ACL's but no packet marking takes place. I can't understand why...anyone any ideas.
From previous reading I don't believe the QoS settings should be assigned to the dialer. I note when doing this though I get packets marked, although strangely only for the Di0 and not for virtual-access 2 .
Regards
