Problem with 2611XM
May 11, 2005 0 Replies
If I upgrade the DRAM in a 2611XM router to greater than 64MB it no longer recognizes the fast0/1 interface. On boot up and in the logs it shows %AMDP2_FE-1-INITFAIL: CSR0=0x0000
It works fine with 1x 64MB DRAM DIMM or 2 x 32MB DRAM DIMMS - but not with
2x 64MB DRAM DIMMS or 1x 64MB DRAM DIMM and 1 x 32MB DRAM DIMMS
Output for Show Ver:
Technical Support:
(c) 1986-2005 by cisco Systems, Inc. Compiled Mon 25-Apr-05 21:16 by ssearch Image text-base: 0x80008098, data-base: 0x80CD3620
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1) ROM: C2600 Software (C2600-I-M), Version 12.3(13a), RELEASE SOFTWARE (fc2)
Router uptime is 7 minutes System returned to ROM by power-on System image file is "flash:c2600-i-mz.123-13a.bin"
cisco 2611XM (MPC860P) processor (revision 0x100) with 126976K/4096K bytes of me mory. Processor board ID JPE073510PD (4181114897) M860 processor: part number 5, mask 1 Bridging software. X.25 software, Version 3.0.0.
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Router#sh c2600
PLD Status: PLD version information not available.
DIMM Slot 0: DIMM Type : Dual-bank DIMM Size : 64MBytes
DIMM Slot 1: DIMM Type : Dual-bank DIMM Size : 64MBytes
Anyone seen this one before?
Regards,
Steve.
