Serial cable for ip phones
Mar 20, 2006 2 Replies
Do the 79xx series of phones support serial console? and what cable do I need if they do?
Thanks.
I don't believe that they do - there is no need. All the manual configurations for the phone can be handled by the buttons on the front. There is an RS232 port on the back of the phone, but that is not for a console connection. We use it for connections to a 7914 side-cart. Not sure what other devices it supports.
Hope that helps,
Jim
No,
You can console into the ipphone and it has a limited command set there ,there was document available on cisco website in ipphone admin guide that expalined the cable pinout which can be used to console into the phone ,cisco for some reason has removed it from there.
Thanks Aman
