Secure a wireless LAN with a PIX 501?
Mar 11, 2006 1 Replies
Walter Roberson
Your diagram shows both networks as being on the same side of the PIX 501. In that situation, you cannot prevent the two networks from communicating, not unless you can put restrictions on the gateway between them (the netgear in your case.) I gather that 'www' represents the…
Hi there,
Being the paranoid IT person I am (i.e. understanding how easy it is to rip down the security in wireless encryption) I want to create an additional network we'll call this "insecure" and give this access to the internet via my Cisco PIX 501. However I do not want this network to have access to my wired LAN we'll call this "secure".
I am using a Netgear router for my wireless access and so far I have done the following:
----------- ----------- | www | - | pix 501 | -----| ----------- ------------ |- 192.168.10.0 (Secure LAN) | |- 172.30.10.0 (Insecure LAN)
------------- | Netgear | WAN - 192.168.10.3 (Insecure LAN) ------------- LAN - 172.16.30.1
My question therefore is how can I isolate communication between the insecure and secure network? Just allowing 172.30.10.0 clients to access the internet i.e. the pix interface only?
Your help would be greatly appreciated!
Many thanks,
A
I gather that 'www' represents the Internet in the diagram.
If someone in the wireless LAN addresses a packet to 192.168.10.* then the Netgear is going to see that network in its routing table, and will ARP on the outside interface for the target address. That ARP *will* get through to the target IP: although you have the Netgear plugged in to the 501, the four LAN ports on the 501 act as a switch, especially as it is the same subnet being requested.
But in your configuration, you cannot use different subnets for the two LANs, because although you can add a 'route inside' on the PIX for the second subnet, the PIX needs to be able to ARP the destination, and the ARP would not be listened to by the Netgear if the Netgear is in a different subnet. You could -try- setting the next-hop address to be the interface itself: the ARP might then go out "raw" onto the switchports, and the Netgear -might- pay attention to it (depends on the IP stack.)
It is not possible to configure the PIX 501 to filter packets between the four switch ports.
Does your Netgear router happen to be one of the ones that is Linux based?
