Questions on PIX 501
Dec 03, 2005 2 Replies
Hello,
The scenario is the following, would it be possible?
1 PIX 501 with a DHCP external IP. The PIX is not supposed to reboot often, like, ... never :-)
Behind the PIX, 172.25.80.0/24, .1 being the inside IP address.
For the Lan behind, 172.25.80.10-20 will be assigned dynamically, PIX being a dhcp server for the inside.
Inside the LAN, my question is about a FreeBSD sever I want to assign a static IP, like .50. From the Outside internet, I need to static nat the inside FreeBSD to reach the SSH port on 22/tcp. Being said the PIX 501 will not be reached from the external Internet on the SSH management port, it is possible to nat the 22/tcp external IP to the inside freeBSD server?
Thank you,
Marc
Marc,
If you have enabled shh on the pix. You can not open ssh grom internet to your freebsd.
I have solve this problem to my freebsd with "PAT" port 22 to 2222
access-list outin permit tcp any any eq 2222 static (inside,outside) tcp interface 2222 bsd ssh netmask
255.255.255.255 0 0 access-group outin in interface outside
//Jan
