PIX 501 Split Tunnel?
Apr 26, 2005 5 Replies
Richard Graves
DM, Can you post portions of the config from the host and at least one of the client sites? Off hand I would agree with you that it sounds like a NAT issue. How granular are you being with your NAT-0 ACLs? -Richard
need to be able to split tunnel from a remote office using a 501.
Situation follows:
Core Site: PIX 535 Remote Site: PIX 501
IPSEC tunnel between core and remote is operational and stable.
core LAN (multiple subnets) can reach remote site and internet.
remote lan can reach core lan, but not internet unless via proxy located on core lan.
501 can ping all hosts, local and remote including internet. Same with
535, but as previously stated, 501 LAN clients can not access internet.
did nothing special on 535 (core) site to enable split tunneling, so it seems strange that I would have to to that on the 501.
I'm fairly certain it's a NAT issue. running a debug of the outside interface for traffic destined for the ISP gateway, internal hosts are not natted, but of course the PIX is showing it's outside IP.
I'm NAT 0-ing the traffic between the remote site and core site so that servers at the core can reach out and touch clients on the 501.
Anyone have any ideas?
dm
DM,
-Richard
pretty granular. The remote site is on a private 10. net with a /25 mask, and the tunnel only allows them to get to a server farm on a different private net (with a /24) mask.
names name 10.x.x.0 RemoteLAN name 172.x.x..0 ServerFarm
access-list TunnelTraff permit ip RemoteLAN 255.255.255.128 ServerFarm
255.255.255.0 access-list TunnelTraff permit icmp RemoteLAN 255.255.255.128 ServerFarm 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list TunnelTraff nat (inside) 1 0.0.0.0
Based on what I see here, it looks good. I would change the "nat (inside) 1
0.0.0.0" to "nat (inside) 1 10.x.x.0 255.255.255.128"; but I'm not sure if that's whats causing your problem. Walter, any ideas?
-Richard
I can do that, but not sure why. if I'm natting everything with nat (inside) 1 0.0.0.0, wouldn't this just limit the scope?
I generally try to be as granular as possible with Cisco configs; I've had problems before that were caused by being to permissive. As I said, I don't know if this will solve your problem or not, it was just something that I was different than the way that I would do things.
-Richard
