RSPAN Trunked port - 6509
Oct 27, 2005 3 Replies
Jump to replies (3)
Hi All,
I am wanting to do an RSPAN session on my 6509 of a trunked port. Once I setup the RSPAN session by using the command 'set rspan source 6/48
445 both', the traffic seems only to go to the RSPAN VLAN, it doesn't continue to flow to the other side of the trunked port..
I am guessing I am using the commmand incorrectly as I am redirecting the traffic only to the RSPAN vlan, it should be going to both the RSPAN vlan and to the other side of the trunked port.
Help
Paul
Hi All,
Help
Paul
hi there ..
here is the configuration help..
Rave
Rspan essentially forwards whatever traffic you are spanning ('both' of port 6/48 in your case) onto a VLAN (445). You then listen to that vlan to hear the spanned traffic. The VLAN you've created must stretch across all switches between you ad the monitored port.
So vlan 445 is the vlan you've created just for RSPAN traffic.
You are monitoring port 6/48 on the switch you issued this command on.
You then need to log into the switch you sniffer/PC is on. You then issue the rspan destination command. This sends all the traffic on the
445 to you port. Basically...
set rspan destination mod/port 445
Just check the syntax--i think i got that right. DiGiTAL_ViNYL (no email)
