RSPAN Ingress Problem
Jul 25, 2007 3 Replies
Jump to replies (3)
We are trying to install a websense server, and need the websense server to see all traffic to and from our firewall. The firewall and the websense server are connected to different switches, so we set up an Rspan session.
Our infrastructure looks like this:
Firewall - conected to port 1/1 of a Catos 6506 Webense - connected to port g0/35 on a 3560
On the 6506: set vlan 200 rspan name Websense state active set rspan source 1/1 200 both session 3 multicast enable
On the 3560: monitor session 3 source remote vlan 200 monitor session 3 destination interface G 0/35 ingress vlan 117
The problem is we are unable to communicate with the Websense server because the ingress isn't working.
GigabitEthernet0/35 is up, line protocol is down (monitoring) Hardware is Gigabit Ethernet, address is 0014.f2ac.eea3 (bia
0014.f2ac.eea3) MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX input flow-control is off, output flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:00:07, output hang never Last clearing of "show interface" counters 10w5d Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops:
0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 2000 bits/sec, 2 packets/sec 5 minute output rate 5000 bits/sec, 2 packets/sec 1782422 packets input, 375991157 bytes, 0 no buffer Received 28835 broadcasts (0 multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 0 input packets with dribble condition detected 8884370 packets output, 1642299926 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out
switch#show monitor Session 3
--------- Type : Remote Destination Session Source RSPAN VLAN : 200 Destination Ports : Gi0/35 Encapsulation : Native Ingress : Enabled, default VLAN = 117 Ingress encapsulation: Untagged
switch#show run int g0/35 ! interface GigabitEthernet0/35 switchport access vlan 117 srr-queue bandwidth share 10 10 60 20 srr-queue bandwidth shape 10 0 0 0 queue-set 2 mls qos trust cos auto qos voip trust spanning-tree portfast end
I am at a loss. All documentation shows that the ingress command should work, but I am unable to get this working. Please let lend a hand if you have exerience with Rspan or port monitoring.
I can't actully explain exactly what yuo are seeing however, my experience is the same as yours. I have seen this feature work on some platform or other sometime (3550XL?) but it does not seem to work on
6500 (sup720) 4500 SE IV 3560 3750
I have given up all hope of it ever working and suggest that you arrange for a second network interface on your server.
My guess is that the behaviour is platform dependent and that it will be documented somewhere.
Quite frustrating I agree.
I'd second this comment - I got RSPAN working once across two 3750 stacks, disabled it, and later on when I re-entered exactly the same commands, it no longer worked (i.e. saw no ingress traffic on the destination port). Made no sense to me & I've never gone back to look at it again since. As it did work, it would seem to indicate a bug maybe... but I never investigated it further to confirm this.
Hmmm.
I think that this is different. I have no trouble with SPAN itself but on some platforms you can use a port as a SPAN destination AND as a normal network port. It's the latter bit that Cisco seem to have phased out, but have left in the command line interface. There is I recall an RSPAN bug in the 2950 whch will never be fixed but otherwise the SPAN (R too) function itself works perfectly in my experience.
SPAN traffic is Rx or Tx and the Ingress bit refers to normal network traffic on the port.
