Timers spf
Oct 28, 2005 1 Replies
In an ospf network do routers in the same area need to have the same spf timers setting? Or can a set of routers that need quicker convergence have their timer spf set independent of the rest of the area?
Tx
HelloInterval The length of time, in seconds, between the Hello Packets that the router sends on the interface. This value is advertised in the router's Hello Packets. It must be the same for all routers attached to a common network.
RouterDeadInterval After ceasing to hear a router's Hello Packets, the number of seconds before its neighbors declare the router down. This is also advertised in the router's Hello Packets in their RouterDeadInterval field. This should be some multiple of the HelloInterval (say 4). This value again must be the same for all routers attached to a common network.
