Routing problem
May 23, 2007 4 Replies
Jump to replies (4)
I am working right now with a single router. Ethernet connection is pointing towards my firewall and my serial connection my internal network. I can ping my firewall from my router but if I do a extended ping I cannot reach my firewall from my internal network.
2500B#ping 192.168.20.98
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.20.98, timeout is 2 seconds: !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max = 1/12/48 ms
2500B#ping Protocol [ip]: Target IP address: 192.168.20.98 Repeat count [5]: Datagram size [100]: Timeout in seconds [2]: Extended commands [n]: y Source address or interface: 192.168.40.2 Type of service [0]: Set DF bit in IP header? [no]: Validate reply data? [no]: Data pattern [0xABCD]: Loose, Strict, Record, Timestamp, Verbose[none]: Sweep range of sizes [n]: Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.20.98, timeout is 2 seconds: ..... Success rate is 0 percent (0/5)
2500B#show ip route Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area * - candidate default, U - per-user static route, o - ODR P - periodic downloaded static route
Gateway of last resort is 192.168.20.98 to network 0.0.0.0
192.168.40.0/30 is subnetted, 1 subnets C 192.168.40.0 is directly connected, Serial0 192.168.20.0/28 is subnetted, 1 subnets C 192.168.20.96 is directly connected, Ethernet0 S* 0.0.0.0/0 [1/0] via 192.168.20.98
I am unable to reach my firewall at 192.168.20.98 from 192.168.40.2 s0.
I have been working on this a few days and cannot figure it out.
2500B#show run Building configuration...
Current configuration : 771 bytes ! version 12.1 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname 2500B ! enable password 7 151A0E1E09253825 ! ! ! ! ! ip subnet-zero no ip domain-lookup ip host 2500A 192.168.40.1 ! ! ! ! interface Ethernet0 ip address 192.168.20.107 255.255.255.240 ! interface Serial0 ip address 192.168.40.2 255.255.255.252 ! interface Serial1 no ip address shutdown ! router rip version 2 passive-interface Ethernet0 network 192.168.20.0 network 192.168.40.0 ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.20.98 no ip http server ! ! line con 0 password 7 10460C0B0818010A logging synchronous login line aux 0 line vty 0 password 7 0829495C04161616 login line vty 1 4 login ! end
Is your firewall configured to route
192.168.40.0/30 via 192.168.20.107 ??
If that's not the case, the replies to your ping will be sent elsewhere by the firewall.
Rainer
The firewall is my gateway to the internet. I can ping the firewall sucessfully from the router, however when I try to ping from the serial interface of the router through the ethernet interface I get nothing. I am using a sonic wall soho 3 which will be replace by a PIX
520 as soon as I finish my CCNA studies. I only thought that you had to make allow trafic both ways with an ACL (which I am not using). I cannot wait to get past this CCNA so I can fire up my PIX. I know it is overkill for my needs, but it is what I need for my cisco pathway.
Bob
Not on a router ... if there is no ACL all traffic is allowed.
Try a traceroute from the fire to the router (and vice versa) ... May be that digs up something.
Does your firewall know where 192.168.40.0/30 is? It needs a route to that network via 192.168.20.107 else it ain't gonna work. You could put a static route on the firewall for it, although I guess you want it to learn about the route (and others) via RIP. RIP is not advertising to the firewall because of the passive-interface command. If you are expecting it to work via RIP then you could remove the passive-interface command and make sure that the firewall is running RIP.
Luggy
