Two Servers Communication Problem
May 23, 2007 6 Replies
Jump to replies (6)
Hi
This is cheema here.
My friend in another city is facing a problem, can you help us and give some hints/tips to troubleshoot the problem
1) PC1(Enterprise Server, mail server) connected to GIGA port on cat 4003 switch
2) PC2( mail server in cluster) connected to fastethernet port on cat
4003 switch
I got a traffic capture of few hundered frames. Once of the frames said
"session rejected for unspecified reasons"
PC1 rejects PC2
I think there is some TCP congestion control issue and if the PC1 is shifted to Fastethernet port, the issue should be resolved
What is your valuable opinion
Thanks Cheema
Hi
4003 switch
4003 switch
PC1 rejects PC2
Thanks Cheema
I don't think that is your issue. Congestion would cause retransmissions or extra latency (no more than about 10ms if its gig to 100meg), but should not cause the 'unspecified' error. If the session is rejected, this is above the network layer and you need to look at your application error logs or anything else. Just my 2 cents.
Dear Trendkill
Thanks a lot for your valuable reply
Regards Cheema
