Router Cisco 7204VXR
May 10, 2006 3 Replies
Jump to replies (3)
I am experiencing a problem with a Cisco Router 7204VXR with the fastEthernet interface. The board is model
PA-2FE-TX (FE2/0 and FE2/1): the FE2/1 seems to work correctly, while I have problems with the FE2/0. After
putting it up and as soon as a data traffic greater than a ping passes through it, the interface becomes
"frozen", still remaining up. Sometimes this fact causes problems also to the other interface (FE2/1). I also replaced the board, but the problem remains. I observed the presence of a lot of collisions (in
half-duplex mode), while in full duplex-mode neither a ping works.
Thanks in advance for your help
If you replaced the port adpater with a known working adapter and the problem persists, it may indicate that the slot is damaged.
Whan events do you have in your log when this happens? Something should be recorded, and this should give you a clue, what's going on. Put more details in your post.
Also, do you have Cisco support for your router? Why don't youcall TAC to help you with a troubleshooting?
Good luck,
Mike
