Reset of PIX console port.
Feb 03, 2006 3 Replies
Jump to replies (3)
I tried to access my PIX525 through minicom under Linux. Unfortunately I didn't disable the modem feature before starting minicom. Now the PIX doesn't respond on console port even using HyperTerminal. Is there a command to reset the console port without reloading the PIX?
Or is that the only way? :(
Alex.
I tried to access my PIX525 through minicom under Linux. Unfortunately I didn't disable the modem feature before starting minicom. So minicom sent the init string to the serial port. Now the PIX doesn't respond on console port even using HyperTerminal. I think that the serial port got confused. Is there a command to reset the console port without reloading the PIX?
Alex.
Alex.
not sure if this is the solution, but you could try and set the console timeout to 1 (minute), it defaults to 0, which means that it does never time out. The relevant command is:
console timeout 1
Regards,
snipped-for-privacy@solutionfinders.nl
