Redirecting packets with route-maps through the same interface.
Apr 06, 2006 1 Replies
Redirecting packets with route-maps through the same interface. open original image
Hi all,
I would like to use a route map on the interface Vlan 1 of a 877 and redirect them out of the same interface. I applied the route-map but it doesn't work. Is it possible or packets must be forwarded through a different interface. My LAN has a router as a default gateway but the real gateway is a firewall and the router forward everything to the firewall. Every device is on the same logical WAN. I want to do a trasparent proxy and I want to put the route-map on the interface but packets that will match the rules (http traffic) will exit the same interface.
I did a test but it failed.
TIA,
Alex
Sending the packet back out on the interface it came in should be possible. You might have to turn off ICMP redirects etc.
I tried the following simple experiment with 2 routers connected back-to-back via their ethernet interfaces
Router1 ====== interface Ethernet0 ip address 20.20.20.1 255.255.255.0 no keepalive ! ip route 0.0.0.0 0.0.0.0 20.20.20.2
Router2 ====== interface Ethernet0 ip address 20.20.20.2 255.255.255.0 ip policy route-map TEST no keepalive ! access-list 1 permit any ! route-map TEST permit 10 match ip address 1 set ip next-hop 20.20.20.1
This does send all packets received on ethernet0 of Router2 back out on ethernet0. (Note that the above configuration does not do anything useful; it was only meant to check if the packet can be forced out of the interface it came in on using a route map.)
Cisco da Gama
