Associate with 871W, no IP address
Apr 06, 2006 15 Replies
Jump to replies (15)
I am working with a Cisco 871W. No fewer than three computers associate to it, gain an IP address from it, and connect to the outside world through it. A new addition to the network is having the following issue: It associates, but never gains an IP. The only difference between any of these systems is that the computer that does not gain an IP address is 802.11b, where the others are all g. There is no indication of any dhcp activity to the 871W, according to show log, though I can see it associate. I am at a loss, and any help would be appreciated.
-tom
give it a static and see what happens.
XP shows wireless connectivity ("Signal Strength Excellent, Connected at 11Mpbs"), but can't ping the 871W, or of course, anything beyond.
-tom
How about SSID and or encryption if any used. You said you seen it associate, does it give the mac address of the host, and from the 871 can you do a link test.
Couple of things to check. Ensure bridge/router is broadcasting ssid, or your laptop has the correct ssid. Ensure 802.11b is enabled via SDM. If you are associated you should be able to perform a link test, see if that works.
Is the 871 configured for radius. You may have to add the new host to the radius server if it is being used.
  1. What version of IOS is load on 871W
  2. enable dhcp debugging and see if AP receives DHCP discover message from PC
conf t logging buffer 10000 debug wri mem
debug dhcp detail
show log
Use the following command before and after to see if AP receives a DHCP request from PC
show ip dhcp server statistics
3.Make sure the 802.11b speeds are set to basic:
basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0
  1. What is the make and model of the 802.11b wireless adapter and its client software version ?
  2. As others have suggested, try configuring an static IP address to see if you can then ping AP.
  3. Does the PC have SP2 service pack installed ?
No, no radius - local authentication only.
I am not broadcasting SSID, quite intentially. I am sure that the computer has the correct SSID, because of the establishment of a link (defined as the XP machine indicating the link).
I will have to learn how to do a link test from the 871W, and post the results.
How/why would 802.11b be enabled/disabled? Is there a way to disable
802.11b on an 802.11g device? Thanks
The wireless adapter is a mini-pci device in a Dell 8200 laptop, not sure of brand. Please see above post for results of assigning a static IP (didn't work). Yes on SP2. Please see config file posted below.
! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers !
! logging buffered 51200 debugging logging console critical ! clock timezone PCTime -8 clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00 no aaa new-model ip subnet-zero ip cef ip dhcp excluded-address 192.168.0.1 192.168.0.49 ! ! ip dhcp pool sdm-pool1 import all network 192.168.0.0 255.255.255.0 dns-server 4.2.2.2 default-router 192.168.0.3 ! ! ip inspect name DEFAULT100 cuseeme ip inspect name DEFAULT100 ftp ip inspect name DEFAULT100 h323 ip inspect name DEFAULT100 icmp ip inspect name DEFAULT100 netshow ip inspect name DEFAULT100 rcmd ip inspect name DEFAULT100 realaudio ip inspect name DEFAULT100 rtsp ip inspect name DEFAULT100 esmtp ip inspect name DEFAULT100 sqlnet ip inspect name DEFAULT100 streamworks ip inspect name DEFAULT100 tftp ip inspect name DEFAULT100 tcp ip inspect name DEFAULT100 udp ip inspect name DEFAULT100 vdolive ip tcp synwait-time 10 no ip domain lookup ip domain name yourdomain.com ip name-server 4.2.2.2 ip ssh time-out 60 ip ssh authentication-retries 2
! no ftp-server write-enable !
! bridge irb ! ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface FastEthernet4 description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$ ip address dhcp ip inspect DEFAULT100 out ip nat outside ip virtual-reassembly ip route-cache flow duplex auto speed auto no cdp enable ! interface Dot11Radio0 no ip address ! encryption key 1 size 40bit 7 1234567889 transmit-key encryption mode wep mandatory ! ssid myssidrighthere authentication open ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 station-role root no dot11 extension aironet l2-filter bridge-group-acl no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address ip tcp adjust-mss 1452 bridge-group 1 ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address 192.168.0.3 255.255.255.0 ip access-group 100 in ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! ip classless ip route 0.0.0.0 0.0.0.0 dhcp ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended sdm_fastethernet4_in remark SDM_ACL Category=1 ip access-list extended sdm_fastethernet4_in_100 remark SDM_ACL Category=1
! logging trap debugging access-list 1 remark INSIDE_IF=BVI1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 192.168.0.0 0.0.0.255 access-list 100 remark auto-generated by Cisco SDM Express firewall configuratio n access-list 100 remark SDM_ACL Category=1 access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto-generated by Cisco SDM Express firewall configuratio n access-list 101 remark SDM_ACL Category=1 access-list 101 permit udp host 4.2.2.2 eq domain any access-list 101 deny ip 192.168.0.0 0.0.0.255 any access-list 101 permit icmp any any echo-reply access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any unreachable access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip any any access-list 101 remark auto-generated by Cisco SDM Express firewall configuratio n access-list 101 remark SDM_ACL Category=1 access-list 101 remark auto-generated by Cisco SDM Express firewall configuratio n access-list 101 remark SDM_ACL Category=1 access-list 701 permit 000e.3b04.a26c 0000.0000.0000 access-list 701 permit 000b.7d0b.0c60 0000.0000.0000 access-list 701 permit 0014.bf11.f9f7 0000.0000.0000 access-list 701 permit 0090.4bb0.1234 0000.0000.0000 access-list 701 permit 0040.f4d6.2e4a 0000.0000.0000 access-list 701 deny 0000.0000.0000 ffff.ffff.ffff no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip
An established rf link does not mean you have a network link, which is what it looks like you have here. IE the wireless card in the laptop sees the access point, but does not establish a network link. This is where authentication comes in. Use some of the debug commands on the bridge to see what the connection is doing. You can do this on the 1400, do not know if it is available on your wireless router
The SDM manual shows that it can be disabled/enabled. According to the docs you should be able to use both. Is your 871 only capable of 11.g? if that is the case there is your answer.
No, according to the documentation, it is an 802.11b/g device.
Do you know the commands to disable/enable 802.11b?
Thanks
Thanks to everyone for the posts - the resolution follows: I did a link status check from the 871W, and found there was a link. I checked the DHCP log, and found that no DHCP requests were hitting the DHCP server. Checking the properties on the wireless card (Dell TrueMobile 1180) revealed that the WEP Key Index was set to a different number than the Key Index on the router. Changing this value solved the problem. I need to learn more about wireless . . .
Thanks to everyone.
-tom
