Reason 412: The remote peer is no longer responding.
Feb 10, 2006 25 Replies
Most relevant reply
Merv
besides disabling your firewall, verify that you PC is actually transmitting packets. Start a cmd windows and run the command "netstat -s -p ip 60" to see IP sned and receive packet counts
Reason 412: The remote peer is no longer responding. open original image
I just can't get this to work out of the box/running wizard. I'm getting error on client of:
Secure VPN Connection terminated locally by the Client. Reason 412: The remote peer is no longer responding.
What areas should I be looking at please? I've set the VPN Easy Server up and made it Initiate as well as Respond. I'm using a key phrase to connect with. I've tested the VPN server in the SDM software and its says its ok.
Short of an entire dump please let me know what more info you need?
Are you using a firewall on your PC such as Windows XP firewall ?
Did you add the Cisco VPN client as an exception ?
Firewall must be configured to permit UDP ports 500 and 62515 whcih are required for cisco vpn client.
I have F-Secure on client which I think is configured to allow the VPN client - I will check. As for the network there is no software firewall on the server, just the Cisco box. I assume that the wizard setup the correct rules to allow clients in but how do I check this port config?
Thanks for responding - you are the first one in over a month and I was going slowly mad!
I'd never heard of 62515 being required before. I see it listed in the VPN 3000 concentrator FAQ,
with 62514 thru 62524.
The description of the port use given in the FAQ does not suggest to me that the firewall would need to be opened to permit any of those ports: they appear to me to only to be talking from the local machine to itself?
UDP port 62515 - Cisco Systems IPSec Driver to Cisco Systems, Inc. VPN Service
Perhaps depends on where a firewall inserts itself in the dataflow
Are you using IP/ESP, NAT-T, or TCP as your connect (Are you using NAT?)
Make sure you use a NAT-friendly VPN scheme. I think the default is IP/ESP which fails with a lot of NAT devices.
Also try the following commands to see a summary of what is or is not happening:
C:\\Program Files\\Cisco Systems \\ VPN Client\\vpnclient stat traffic
C:\\Program Files\\Cisco Systems \\ VPN Client\\vpnclient stat tunnel
Phillip, Sorry for late reply - have been to France to try and chill from this mess!!
I have NAT on the firewall. What am I using as my connect? Good question! Do I search for this on the firewall or is it configured on the client end - or both?
Thanks, James
I can only test this when at another site - unfortunately I can not be in the same building and "dial in". So progress is slow. However I will add your command prompts tonight and let you know the outcome. I am still very confused by the whole thing as the webhelp that comes with the SDM package is quite frankly - bloody useless!
Phillip has suggested IP/ESP as something to explore - but I am awaiting where I look for this. Also it makes me wonder what the "wizard" is doing in setting up a complex system that basically then fails to work.
Having had to reboot the box due to a total freeze I realise that I have lost some previous settings - c'est la vie! In wandering round the maze again I see I don't have any IPSec Rules (ACL). Do I need some? should not the "wizard" have produced the ones it needs? Does this "wizard" only work on Sundays!?
Thanks
OK, I've just tried from within the site. Hoping that my packets will leave and then come back to establish a link. I now get an error:
Secure VPN Connection terminated locally by the Client. Reason 401: An unrecognized error occurred while establishing the VPN connection.
This happens after I log in:
Negotiating security policies... Securing communications channel...
Can I assume that my security policies are at least set up ok?
Also found this in the log of the client:
1 11:58:32.550 02/14/06 Sev=Warning/3 GUI/0xE3B00003 GI EnumPPP callback timed out.
2 12:00:43.688 02/14/06 Sev=Warning/2 IKE/0xA3000062 Attempted incoming connection from 80.177.223.54. Inbound connections are not allowed.
3 12:08:04.452 02/14/06 Sev=Warning/2 IKE/0xA3000062 Attempted incoming connection from 80.177.223.54. Inbound connections are not allowed.
Have you always been getting as far as getting the messages:
post the firewall config and the contents of the client VPN profile for the connection
post the contents of the PIX firewall log - use command "show log"
is the IP address 80.177.223.54. for your firewall ?
BTW is this a new VPN server setup or are there other users that are able to connect to the VPN server sucessfully?
Here's the config:
Building configuration...
Current configuration : 8568 bytes ! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname Router ! boot-start-marker boot-end-marker ! logging buffered 51200 debugging logging console critical enable secret 5 $1$LR.f$pB8.ZdKhW3GXtV8S4gj3J. ! username James privilege 15 secret 5 $1$lURO$tewOxEtKEAqZxNz7Zdbd4. clock timezone London 0 clock summer-time London date Mar 30 2003 1:00 Oct 26 2003 2:00 aaa new-model ! ! aaa authentication login default local aaa authorization exec default if-authenticated local aaa authorization network default local aaa session-id common ip subnet-zero no ip source-route ! ! ip cef ip inspect name DEFAULT100 cuseeme ip inspect name DEFAULT100 ftp ip inspect name DEFAULT100 h323 ip inspect name DEFAULT100 icmp ip inspect name DEFAULT100 rcmd ip inspect name DEFAULT100 realaudio ip inspect name DEFAULT100 rtsp ip inspect name DEFAULT100 esmtp ip inspect name DEFAULT100 sqlnet ip inspect name DEFAULT100 streamworks ip inspect name DEFAULT100 tftp ip inspect name DEFAULT100 tcp ip inspect name DEFAULT100 udp ip inspect name DEFAULT100 vdolive ip tcp synwait-time 10 no ip bootp server ip domain name XXX ip name-server 158.152.1.58 ip name-server 158.152.1.43 ip ssh time-out 60 ip ssh authentication-retries 2 no ftp-server write-enable ! ! ! ! ! crypto isakmp policy 1 encr 3des hash md5 authentication pre-share group 2 ! crypto isakmp policy 2 hash md5 authentication pre-share group 2 crypto isakmp key pwd address 82.0.98.178 ! crypto isakmp client configuration group groupname key key dns 158.152.1.58 158.152.1.43 wins xxx.xxx.xxx.200 domain XXX pool SDM_POOL_1 include-local-lan max-users 1 max-logins 3 ! ! crypto ipsec transform-set TransformSet1 esp-3des esp-sha-hmac ! crypto ipsec profile IPSecProfile1 set transform-set TransformSet1 ! ! crypto dynamic-map SDM_DYNMAP_1 1 set transform-set TransformSet1 reverse-route ! ! crypto map SDM_CMAP_1 client authentication list default crypto map SDM_CMAP_1 isakmp authorization list default crypto map SDM_CMAP_1 client configuration address respond crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1 ! bridge irb ! ! interface Null0 no ip unreachables ! interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point description $ES_WAN$$FW_OUTSIDE$ no ip redirects no ip unreachables no ip proxy-arp pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface Dot11Radio0 no ip address ! ssid SSIDname authentication open ! speed basic-1.0 2.0 5.5 6.0 9.0 11.0 channel 2462 no cdp enable bridge-group 1 bridge-group 1 spanning-disabled ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address bridge-group 1 ! interface Dialer0 description $FW_OUTSIDE$ ip address 80.177.223.54 255.0.0.0 ip access-group 101 in no ip redirects no ip unreachables no ip proxy-arp ip inspect DEFAULT100 out ip nat outside ip virtual-reassembly encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap callin ppp chap hostname snipped-for-privacy@lon1-aj1e.demonadsl.co.uk ppp chap password 7 05082E1D2042405A0A ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address xxx.xxx.xxx.100 255.255.255.0 ip access-group 100 in no ip redirects no ip unreachables no ip proxy-arp ip nat inside ip virtual-reassembly ip route-cache flow ip tcp adjust-mss 1452 crypto map SDM_CMAP_1 ! ip local pool SDM_POOL_1 xxx.xxx.xxx.50 xxx.xxx.xxx.55 ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ! ip http server ip http access-class 2 ip http authentication local ip http secure-server ip http timeout-policy idle 600 life 86400 requests 10000 ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload ! logging trap debugging logging xxx.xxx.xxx.100 logging 80.177.223.54 access-list 1 remark INSIDE_IF=BVI1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit xxx.xxx.xxx.0 0.0.0.255 access-list 2 remark HTTP Access-class list access-list 2 remark SDM_ACL Category=1 access-list 2 permit xxx.xxx.xxx.0 0.0.0.255 access-list 2 deny any access-list 100 remark auto generated by Cisco SDM Express firewall configuration access-list 100 remark SDM_ACL Category=1 access-list 100 permit ip host xxx.xxx.xxx.50 any access-list 100 permit ip host xxx.xxx.xxx.51 any access-list 100 permit ip host xxx.xxx.xxx.52 any access-list 100 permit ip host xxx.xxx.xxx.53 any access-list 100 permit ip host xxx.xxx.xxx.54 any access-list 100 permit ip host xxx.xxx.xxx.55 any access-list 100 permit udp any host xxx.xxx.xxx.100 eq non500-isakmp access-list 100 permit udp any host xxx.xxx.xxx.100 eq isakmp access-list 100 permit esp any host xxx.xxx.xxx.100 access-list 100 permit ahp any host xxx.xxx.xxx.100 access-list 100 deny ip 80.0.0.0 0.255.255.255 any access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto generated by Cisco SDM Express firewall configuration access-list 101 remark SDM_ACL Category=1 access-list 101 permit ip host xxx.xxx.xxx.50 any access-list 101 permit ip host xxx.xxx.xxx.51 any access-list 101 permit ip host xxx.xxx.xxx.52 any access-list 101 permit ip host xxx.xxx.xxx.53 any access-list 101 permit ip host xxx.xxx.xxx.54 any access-list 101 permit ip host xxx.xxx.xxx.55 any access-list 101 permit udp any host 80.177.223.54 eq non500-isakmp access-list 101 permit udp any host 80.177.223.54 eq isakmp access-list 101 permit esp any host 80.177.223.54 access-list 101 permit ahp any host 80.177.223.54 access-list 101 permit udp host 82.0.98.178 host 80.177.223.54 eq non500-isakmp access-list 101 permit udp host 82.0.98.178 host 80.177.223.54 eq isakmp access-list 101 permit esp host 82.0.98.178 host 80.177.223.54 access-list 101 permit ahp host 82.0.98.178 host 80.177.223.54 access-list 101 permit udp host 158.152.1.43 eq domain host
80.177.223.54 access-list 101 permit udp host 158.152.1.58 eq domain host 80.177.223.54 access-list 101 deny ip xxx.xxx.xxx.0 0.0.0.255 any access-list 101 permit icmp any host 80.177.223.54 echo-reply access-list 101 permit icmp any host 80.177.223.54 time-exceeded access-list 101 permit icmp any host 80.177.223.54 unreachable access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 172.16.0.0 0.15.255.255 any access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip host 0.0.0.0 any access-list 101 deny ip any any access-list 101 remark IPSec Rule access-list 101 permit ip xxx.xxx.xxx.0 0.0.0.255 xxx.xxx.xxx.0 0.0.0.255 access-list 103 remark SDM_ACL Category=2 access-list 103 deny ip any host xxx.xxx.xxx.50 access-list 103 deny ip any host xxx.xxx.xxx.51 access-list 103 deny ip any host xxx.xxx.xxx.52 access-list 103 deny ip any host xxx.xxx.xxx.53 access-list 103 deny ip any host xxx.xxx.xxx.54 access-list 103 deny ip any host xxx.xxx.xxx.55 access-list 103 permit ip xxx.xxx.xxx.0 0.0.0.255 any access-list 105 remark VTY Access-class list access-list 105 remark SDM_ACL Category=1 access-list 105 permit ip xxx.xxx.xxx.0 0.0.0.255 any access-list 105 deny ip any any access-list 700 permit 0001.e694.aa0a 0000.0000.0000 access-list 700 deny 0000.0000.0000 ffff.ffff.ffff dialer-list 1 protocol ip permit no cdp run route-map SDM_RMAP_1 permit 1 match ip address 103 ! ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 no modem enable transport preferred all transport output telnet line aux 0 transport preferred all transport output telnet line vty 0 4 access-class 105 in transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 ntp server 130.88.203.12 prefer end
I'm a bit unclear about the PIX bit - the client has a log but it is only populated on attempted connection. At the moment it only contains this:
Cisco Systems VPN Client Version 4.6.00.0045 Copyright (C) 1998-2004 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2 Config file directory: C:\\Program Files\\Cisco Systems\\VPN Client
I can increase the logging of such things like IPSec, IKE, PPP, GUI etc.
Thanks for all your help.
And yes 80.177.223.54 is the external NAT'd address of the firewall (Cisco 857W).
This is a new setup - and only one person (myself) will be allowed in. Also forgot to say that the Negotiating security etc is new to me!! Must be getting somewhere, right. Trouble is that was from within the site and all previous tests have been from outside. Not sure what diff that makes...
On your VPN client profile setup, please confirm that the groupname is set to"groupname" and the password is set to "key"
BTW I would suggest for clarity during testing that you change these settings on both the 837W and your PC. For example use a captilized groupname and password
clear the logging buffer ("clear log") , attempt a connection, and then post the contents of the 857's logging buffer (" show log')
