The remote peer is no longer responding
Oct 22, 2006 4 Replies
Jump to replies (4)
I am using VPN client to connect to a PIX firewall. I get the error: " Secure VPN connection terminated locally by the Client. Reason 412: The remote peer is no longer responding". I am attaching the log below. Someone (Walter?) please help me. Thanks & Regards
Cisco Systems VPN Client Version 4.0.5 (Rel) Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2
1 19:19:48.890 10/22/06 Sev=Info/4 CM/0x63100002 Begin connection process
2 19:19:48.906 10/22/06 Sev=Info/4 CVPND/0xE3400001 Microsoft IPSec Policy Agent service stopped successfully
3 19:19:48.906 10/22/06 Sev=Info/4 CM/0x63100004 Establish secure connection using Ethernet
4 19:19:48.906 10/22/06 Sev=Info/4 CM/0x63100024 Attempt connection with server "209.178.198.242"
5 19:19:49.921 10/22/06 Sev=Info/6 IKE/0x6300003B Attempting to establish a connection with 209.178.198.242.
6 19:19:49.921 10/22/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Nat-T), VID(Frag), VID(Unity)) to 209.178.198.242
7 19:19:49.937 10/22/06 Sev=Info/4 IPSEC/0x63700008 IPSec driver successfully started
8 19:19:49.937 10/22/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
9 19:19:50.375 10/22/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.242
10 19:19:50.375 10/22/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, VID(?), VID(Unity)) to 209.178.198.242
16 19:19:50.375 10/22/06 Sev=Info/4 IKE/0x63000082 IKE Port in use - Local Port = 0x01F4, Remote Port = 0x01F4
17 19:19:50.375 10/22/06 Sev=Info/4 CM/0x6310000E Established Phase 1 SA. 1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
18 19:19:50.375 10/22/06 Sev=Info/4 CM/0x6310000E Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
19 19:19:50.390 10/22/06 Sev=Info/5 IKE/0x6300005D Client sending a firewall request to concentrator
20 19:19:50.390 10/22/06 Sev=Info/5 IKE/0x6300005C Firewall Policy: Product=Cisco Systems Integrated Client, Capability= (Centralized Protection Policy).
21 19:19:50.406 10/22/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 209.178.198.242
22 19:19:50.453 10/22/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.242
23 19:19:50.453 10/22/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 209.178.198.242
31 19:19:50.578 10/22/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.242
32 19:19:50.578 10/22/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK QM *(Retransmission) to 209.178.198.242
37 19:20:00.703 10/22/06 Sev=Info/4 IKE/0x63000021 Retransmitting last packet!
38 19:20:00.703 10/22/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK QM *(Retransmission) to 209.178.198.242
39 19:20:05.703 10/22/06 Sev=Info/4 IKE/0x63000021 Retransmitting last packet!
40 19:20:05.703 10/22/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK QM *(Retransmission) to 209.178.198.242
41 19:20:10.703 10/22/06 Sev=Info/4 IKE/0x6300002D Phase-2 retransmission count exceeded: MsgID=041CAED1
42 19:20:10.703 10/22/06 Sev=Info/6 IKE/0x6300003D Sending DPD request to 209.178.198.242, seq# = 1691596402
43 19:20:10.703 10/22/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to
209.178.198.242
44 19:20:10.703 10/22/06 Sev=Info/4 IKE/0x63000013 SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 209.178.198.242
45 19:20:10.703 10/22/06 Sev=Info/4 IKE/0x63000048 Discarding IPsec SA negotiation, MsgID=041CAED1
46 19:20:10.750 10/22/06 Sev=Info/5 IKE/0x6300002F Received ISAKMP packet: peer = 209.178.198.242
47 19:20:10.750 10/22/06 Sev=Info/4 IKE/0x63000014 RECEIVING > ISAKMP OAK INFO *(HASH, DEL) to 209.178.198.242
51 19:20:41.218 10/22/06 Sev=Info/4 IKE/0x6300004A Discarding IKE SA negotiation (I_Cookie=7A8ECEC78AF9ED8C R_Cookie=88BADF7979DF25DC) reason = DEL_REASON_PEER_NOT_RESPONDING
52 19:20:41.218 10/22/06 Sev=Info/4 CM/0x63100012 Phase 1 SA deleted before first Phase 2 SA is up cause by "DEL_REASON_PEER_NOT_RESPONDING". 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
53 19:20:41.218 10/22/06 Sev=Info/5 CM/0x63100025 Initializing CVPNDrv
54 19:20:41.218 10/22/06 Sev=Info/4 IKE/0x63000001 IKE received signal to terminate VPN connection
55 19:20:41.250 10/22/06 Sev=Info/4 IKE/0x63000085 Microsoft IPSec Policy Agent service started successfully
56 19:20:41.250 10/22/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
57 19:20:41.250 10/22/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
58 19:20:41.250 10/22/06 Sev=Info/4 IPSEC/0x63700014 Deleted all keys
59 19:20:41.250 10/22/06 Sev=Info/4 IPSEC/0x6370000A IPSec driver successfully stopped
You are getting through Phase 1 okay, but having trouble with Phase 2.
In my experience, Phase 1 is all exchanged with the public IP of the client, but Phase 2 is exchanged with the IP that has been negotiated for the link.
I have seen full Phase 1 with Phase 2 completely failed; in our situation, the problem was that the routing for the negotiated IP went by a different path than for the basic link IP -- the way we had things arranged, it was even going to a different interface and different vlan. It was a real puzzle in the beginning, until eventually I happened to notice that the interface name I was seeing in the log for the Phase 2 negotiations wasn't the expected interface.
Walter Roberson wrote:
Hi Walter, Many thanks for analyzing the logs. The IP address I used was that of the PIX firewall. Should I be using the IP address of the host behind the firewall? Also, I am not clear about the solution you are suggesting. I am attaching the firewall config. Thanks & Regards
iexpect-corp# show config : Saved : PIX Version 6.1(1) nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password encrypted passwd encrypted hostname iexpect-corp fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 1720 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 no fixup protocol smtp 25 names name 192.168.5.13 njrep1 name 192.168.5.150 trig1 name 192.168.5.151 trig2 name 192.168.5.61 brett name 192.168.5.152 sfg2 name 192.168.5.9 corp-smtp2 name 192.168.5.10 corp-smtp name 192.168.11.10 corpsmtp2 name 192.168.11.58 sfg name 192.168.11.73 pepsanchez access-list ipsec permit ip 192.168.5.0 255.255.255.0 10.0.255.0
255.255.255.0 access-list ipsec permit ip 192.168.11.0 255.255.255.0 10.0.255.0 255.255.255.0 access-list incoming permit tcp any host 209.178.198.243 eq smtp access-list incoming permit tcp any host 209.178.198.244 eq smtp access-list incoming permit icmp any any echo-reply access-list incoming permit icmp any any time-exceeded access-list incoming permit icmp any any unreachable access-list incoming permit tcp any host 209.178.198.243 eq 5631 access-list incoming permit tcp any host 209.178.198.243 eq 5632 access-list incoming permit udp any host 209.178.198.243 eq 5632 access-list incoming permit udp host 216.34.112.198 eq dnsix any access-list incoming permit udp host 216.33.202.54 eq dnsix any access-list incoming permit tcp any eq telnet host 216.74.138.147 access-list incoming permit tcp any host 209.178.198.244 eq telnet access-list incoming permit tcp any eq telnet host 209.178.198.244 access-list incoming permit tcp any host 209.178.198.243 eq www access-list incoming permit tcp any host 209.178.198.244 eq www access-list incoming permit tcp any host 209.178.198.244 eq ftp access-list incoming permit tcp any eq ftp host 209.178.198.244 access-list incoming permit tcp any host 209.178.198.245 eq 22 access-list incoming permit tcp any host 209.178.198.245 eq www access-list incoming permit tcp any host 209.178.198.243 eq 3389 access-list incoming permit tcp any host 209.178.198.244 eq 3389 access-list incoming permit tcp any host njrep1 eq 22 access-list incoming permit tcp any host njrep1 eq ftp access-list incoming permit tcp any host 209.178.198.247 eq 4662 access-list incoming permit udp any host 209.178.198.247 eq 4672 access-list incoming permit tcp any host 209.178.198.249 eq www access-list incoming permit tcp any host 209.178.198.245 eq 443 access-list incoming permit tcp any host 209.178.198.249 eq 22 access-list incoming permit tcp any host 209.178.198.254 eq 5900 access-list incoming permit tcp 202.138.142.224 255.255.255.224 host 209.178.198.248 eq 443 access-list incoming permit tcp any host 209.178.198.249 eq 443 access-list incoming permit tcp any host 209.178.198.254 eq www access-list incoming permit tcp any host 209.178.198.254 eq 129 access-list incoming permit tcp any host 209.178.198.254 eq 132 access-list incoming permit tcp any host 209.178.198.243 eq ftp access-list incoming permit icmp any host 209.178.198.254 access-list incoming permit icmp any host 209.178.198.243 access-list incoming permit icmp any host 209.178.198.248 access-list incoming permit tcp any host 209.178.198.243 access-list outgoing permit tcp any any access-list outgoing permit icmp any any access-list outgoing permit icmp any any echo-reply access-list outgoing permit udp any any access-list outgoing permit tcp any any eq www access-list outgoing permit tcp any host 216.239.35.101 eq www access-list outgoing permit udp any host 216.34.112.198 eq dnsix access-list outgoing permit udp any host 216.33.202.54 eq dnsix pager lines 24 logging on interface ethernet0 10baset interface ethernet1 10baset mtu outside 1500 mtu inside 1500 ip address outside 209.178.198.242 255.255.255.240 ip address inside 192.168.5.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool corp-home 192.168.99.1-192.168.99.224 pdm history enable arp timeout 60 global (outside) 1 209.178.198.252-209.178.198.253 global (outside) 1 209.178.198.251 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 alias (inside) 192.168.5.58 209.178.198.248 255.255.255.255 alias (inside) sfg2 209.178.198.249 255.255.255.255 alias (inside) corp-smtp 209.178.198.243 255.255.255.255 alias (inside) 192.168.5.149 209.178.198.254 255.255.255.255 alias (inside) 192.168.11.150 209.178.198.245 255.255.255.255 static (inside,outside) 209.178.198.245 trig1 netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.246 trig2 netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.243 corp-smtp netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.249 sfg2 netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.254 192.168.5.149 netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.250 192.168.5.63 netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.244 corp-smtp2 netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.248 sfg netmask 255.255.255.255 0 0 static (inside,outside) 209.178.198.247 pepsanchez netmask 255.255.255.255 0 0 access-group incoming in interface outside route outside 0.0.0.0 0.0.0.0 209.178.198.241 1 route inside 192.168.11.0 255.255.255.0 192.168.5.2 1 route inside 192.168.254.0 255.255.255.0 192.168.5.2 1 timeout xlate 3:00:00 timeout conn 3:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius http server enable http corp-smtp2 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt ipsec pl-compatible no sysopt route dnat crypto ipsec transform-set iexpect esp-des esp-md5-hmac crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map corp 1 ipsec-isakmp crypto map corp 1 match address ipsec crypto map corp 1 set peer 216.74.138.157 crypto map corp 1 set transform-set iexpect crypto map corp 10 ipsec-isakmp dynamic dynmap crypto map corp client configuration address initiate crypto map corp client configuration address respond crypto map corp interface outside isakmp enable outside isakmp key ******** address 216.74.138.157 netmask 255.255.255.255 isakmp identity address isakmp policy 1 authentication pre-share isakmp policy 1 encryption des isakmp policy 1 hash md5 isakmp policy 1 group 1 isakmp policy 1 lifetime 86400 isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup corphome address-pool corp-home vpngroup corphome dns-server 192.168.1.6 vpngroup corphome wins-server 192.168.1.6 vpngroup corphome default-domain corp.iexpect.com vpngroup corphome idle-time 1800 vpngroup corphome password ******** telnet 0.0.0.0 0.0.0.0 outside telnet corp-smtp 255.255.255.255 inside telnet 192.168.5.2 255.255.255.255 inside telnet 192.168.11.0 255.255.255.0 inside telnet 192.168.5.0 255.255.255.0 inside telnet njrep1 255.255.255.255 inside telnet corp-smtp2 255.255.255.255 inside telnet timeout 5 ssh 0.0.0.0 0.0.0.0 outside ssh 209.178.198.0 255.255.255.0 outside ssh njrep1 255.255.255.255 inside ssh 192.168.5.0 255.255.255.0 inside ssh timeout 5 terminal width 80 Cryptochecksum:eca17c51a788c2eefbaebde0f2ea86f0 iexpect-corp#
You really should upgrade that to get rid of the known security problems. If you are the registered owner of the device (e.g., not bought used via ebay) then you are entitled to a free upgrade to the latest 6.1(*) because of the security issues.
echo-reply is a subset of 'any' so the second permit icmp is redundant.
tcp www is a subset of the earlier tcp 'any' so the above permit is redundant.
permit tcp to a specific hosts' www is a subset of permitting tcp www to 'any', so this statement is redundant against the previous (which in turn is redundant against the first)
These udp are subsets of permit udp 'any' so these are redundant.
These redundancies will not, however, have any effect on your current difficulties.
I was going to give you the standard warning about alias being obsolete, but I see that you are only running 6.1(1), in which it is still officially necessary. (Personally I never found a use for it!) [several static, none involving 192.168.99.1]
Your access-list 'outgoing' appears to be unused.
pl-compatible is obsolete unless you a connecting to a PIX 4 system running an obscure add-on VPN board that uses protocols that predate IPSec.
Better security policies should have lower policy numbers. des md5 group 2 is more secure than des md5 group 1, so put the group 2 entry as a lower policy number than than the group 1 entry.
Okay, what you've done is configured the vpn client software to get a link IP address from you, and that link IP is to be drawn from the address range defined by corp-home, 192.168.99.1-192.168.99.224 .
You do not have a nat 0 access-list for traffic to 192.168.99.* so traffic destined to that range will have its source address NAT'd in accordance with your nat 1 / global 1 policy. So the outgoing VPN traffic will have a source IP of 209.178.198.251, .252, or .253 .
You do not have any static or alias for the destination address range 192.168.99.1-192.168.99.224 so the destination IP for that traffic will not be modified by the NAT process.
At this point, you have a packet that you want to go into the VPN tunnel, and the source IP for that packet is
209.178.198.251 - .253, and the destination IP for that packet is 192.168.99.1-192.168.99.224 . That traffic will be compared to the defined crypto-map match-address policies. The access-list named 'ipsec' is not going to match that traffic because for that access-list the destinations are 10.something .
When you connected via the VPN client software, your connection was permitted by way of the crypto dynamic map configurations. That connection process automatically generated a new temporary access list with a destination equal to the negotiated address for the link, and automatically generated a temporary match-address, and corresponding security associations will be created.
Now what you need to know is what the *source* IP range is for that automatically generated access-list being used in the temporary match-address. And I think what you will find is that the source IP for that list is *not* 209.178.198.251, .252, or .253.
To make a long story short, the fix is:
access-list nonat permit 192.168.5.0 255.255.255.0 192.168.99.0 255.255.255.255 access-list nonat permit 192.168.11.0 255.255.255.0 192.168.99.0 255.255.255.255 nat (inside) 0 access-list nonat
This will keep the PIX from NAT'ing the source IP for the traffic destined to the VPN, so the traffic will match the automatically generated access-list. (Test it, though -- I am not certain that the automatically generated ACL will include 192.168.11.0 as a source)
Hi Walter Many thanks for your kind response in detail. I added the above access lists with a minor modification as follows:
access-list nonat permit ip 192.168.5.0 255.255.255.0 192.168.99.0
255.255.255.255 access-list nonat permit ip 192.168.11.0 255.255.255.0 192.168.99.0 255.255.255.255
Apparently they are not working. Kindly let me know what else to try.
Best Regards
