Re: PTP vs. MPLS
Mar 11, 2005 0 Replies
Thanks to both you and Ivan. You are pretty much confirming my thinking on this.
David
I don't see the point of using MPLS to just interconnect two sites. >
> The advantage with MPLS is where you have multiple sites as MPLS gives
> you any to any connectivity (no nailed up point to point circuits) plus
> Class of Service.
> You can implemented Congestion Control on the router and interconnect
> the two sites using either a T1 Leased Line or Frame Relay.
> Farouq Taj
