Questions on Cisco 3200 MAR Temperature Voltage information
Jul 11, 2006 1 Replies
Questions on Cisco 3200 MAR Temperature Voltage information open original image
Hi:
We are working on Cisco 3200 MAR and want to monitor MAR temperature, voltage and fan speed. We have enabled all the related snmp traps, however, we cannot receive related information.
Our question is:
Does MAR have necessory sensors to provide SNMP information on temperature, voltage and fan speed?
Thank you.
Chibiao
Temperature Sensor
A router equipped with the Cisco 3270 Rugged Router card includes a High-Precision Digital Thermometer and Thermostat ( DS1631 ).
The temperature is sampled every 30 seconds.
A warning is sent to users by using SNMP traps and by flashing the over-temp LED if temperature is below -40'C or above +95'C until the temperature falls back to its normal range.
found at
Sincerely,
Brad Reese BradReese.Com - Cisco Technical Forums
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
