[QOS] minimal hardware and IOS requirement for QOS
Feb 04, 2007 2 Replies
[QOS] minimal hardware and IOS requirement for QOS open original image
Hi all, I have 2 dozen of router to set up for QOS. I plan to upgrade all to at least C805, (there is some old 1600). there would be just a few users behind each leased line (in average of
128kbits) I would like to know if 8M byte of ram is enought ? I beg IOS 12.1 is enought, but I would like to know what minimal IOS version is required for QOS.
thanks for your advices and feedback.
-- dominix
You may wish to investigate the Cisco Feature Navigator.
The Cisco Feature Navigator allows you to quickly find the right Cisco IOS and CatOS software release for the features you want to run on your network.
Sincerely,
Brad Reese
thanks Brad, I didn't remerber of this "feature select" thing. throught I did use this page for comparing IOS :)
-- dominix
