QoS - LLQ on Dialer (ADSL) 3725
Feb 03, 2006 0 Replies
Hello,
c3725-advipservicesk9-mz.123-8.T3.bin
Maybe once again I am missing something however I am unable to get QoS to work on a Dialer.
There are Docs that imply that QoS on Dialers may only be supported over MPPP.
This seems preposterous and I am pretty sure that I have seen LLQ working on a dialer on ADSL on an 837.
sh policy-map int d1 Dialer1
Service-policy output: PM-tointernet
Class-map: CM-voice (match-any) 878199 packets, 188753004 bytes 5 minute offered rate 0 bps, drop rate 0 bps Match: dscp ef 817013 packets, 180365508 bytes 5 minute rate 0 bps Match: dscp cs3 61186 packets, 8387496 bytes 5 minute rate 0 bps Queueing Strict Priority Output Queue: Conversation 136 Bandwidth 270 (kbps) Burst 6750 (Bytes) (pkts matched/bytes matched) 0/0 (total drops/bytes drops) 0/0
Class-map: class-default (match-any) 2063027 packets, 519213659 bytes 5 minute offered rate 7000 bps, drop rate 0 bps Match: any Queueing Flow Based Fair Queueing Maximum Number of Hashed Queues 128 (total queued/total drops/no-buffer drops) 0/0/0
sh policy-map int v 1
As you can see the packets match the policy but there is no queueing/management.
class-map match-any CM-voice match dscp ef match dscp cs3 ! ! policy-map PM-tointernet class CM-voice priority 270 class class-default fair-queue queue-limit 10
interface Dialer1 bandwidth 512 ip address negotiated ip access-group 190 in ip nat outside ip virtual-reassembly service-policy output PM-tointernet encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1 crypto map DELETED
