QOS on C1760
Aug 24, 2006 2 Replies
Hi, new to qos and would like to do the following: voip call centre------routerA------------RouterB---voip phone
IOS (tm) C1700 Software (C1700-SY7-M), Version 12.3(3), RELEASE SOFTWARE (fc2)
router A and B has a 2mb e1 circuit between. would like to setup qos for voip between these routers... any pointers as to what need to take into consideration and how tos?
thanks in advance.
Need some more information:-
How many simultaneous calls do you expect to cross the WAN link? What Codec do you intend to use? Whats the encapsulation of the WAN link? Is it a point-to-point link or some kind of managed service such as FR or MPLS?
James
ants wrote:
I think all you need is LLQ. You have a single phone so all you're going to have is one call going over the link. Even with G.711 you'd only have 100kbps for a call.
I'll look for a good link with a configuration for you and post later.
