QoS Drops counter in Catalyst 3560?
Dec 08, 2007 2 Replies
Thrill5
I think the command you need is "show platform port-asic stats drop". I don't think these are in the same format as the 3550 because QoS is done much differently on 3560/3750 platforms.
QoS Drops counter in Catalyst 3560? open original image
Hi
In the Catalyst 3560 there is some command that is in use for obtaining the drops counters for QoS in the style of the equivalent one in the Catalyst 3550?
show mls qos interface statistics
Thanks in advance.
Can you check below site , may be it helps...
Check the IOS version as well..
Thanks..CK
