Problem with SSL Services Module
Mar 19, 2008 2 Replies
Hi all,
I have one Catalyst 6500 Series with CSM and SSL Services Module. When I am connecting to SSL module whit serial port, de paste command doesn?t work properly.
For example if copy "test" the result of paste comande is "tY.w".
ssl>tY.w
An idea?
ssl(config)#line console 0 ssl(config-line)#??????????????
Regards,
ssl# sh line console 0 Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
  • 0 CTY - - - - - 0 0 0/0 -
Line 0, Location: "", Type: "" Length: 24 lines, Width: 80 columns Status: Ready, Active Capabilities: none Modem state: Ready Async VTS Line Special Chars: Escape Hold Stop Start Disconnect Activation ^^x none - - none Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch 00:10:00 never none not set Idle Session Disconnect Warning never Login-sequence User Response 00:00:30 Autoselect Initial Wait not set Modem type is unknown. Session limit is not set. Time since activation: 00:01:16 Editing is enabled. History is enabled, history size is 20. DNS resolution in show commands is enabled Full user help is disabled Allowed input transports are none. Allowed output transports are telnet ssh. Preferred transport is telnet. No output characters are padded No special data dispatching characters ssl#
Hi all,
ssl>tY.w
An idea?
Regards,
It's probably your terminal emulation software and if your using HyperTerminal, this is definitely your problem. HyperTerminal is very buggy, and an update is available from Hilgraeve, who wrote and supports the software. Hilgraeve has a "enhanced" version that you have to purchase, but there are much better programs than HT, such as SecureCRT.
