Problem with setup of access server (2509)
Jun 02, 2007 1 Replies
I am hoping that someone can give me some suggestions as to how to troubleshoot this. I purchased a cisco 2509 to use as an access server. It is connected to my other routers through an Octal cable. When I attempt to connect to other system through the octal cable it appears to connect however I never receive a prompt to access the router I am attempting to connect to. R1 is up, it is connected to line 1 on the octal cable, and I can log in with a direct console connection
Router#R1 Trying R1 (100.1.1.1, 2001)... Open
But never any prompt to access R1. It just freezes there until I use CTRL-Shift-6, X However the session appears to be established
Router#sh session Conn Host Address Byte Idle Conn Name
  • 1 R1 100.1.1.1 0 1 R1
it appears the lines are ready to use (I think)
Router#sh line Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
  • 0 CTY - - - - - 2 0 0/0 -
  • 1 TTY 9600/9600 - - - - - 2 0 0/0 - 2 TTY 9600/9600 - - - - - 0 0 0/0 - 3 TTY 9600/9600 - - - - - 0 0 0/0 - 4 TTY 9600/9600 - - - - - 0 0 0/0 - 5 TTY 9600/9600 - - - - - 0 0 0/0 - 6 TTY 9600/9600 - - - - - 0 0 0/0 - 7 TTY 9600/9600 - - - - - 0 0 0/0 - 8 TTY 9600/9600 - - - - - 0 0 0/0 - 9 AUX 9600/9600 - - - - - 0 0 0/0 - 10 VTY - - - - - 0 0 0/0 - 11 VTY - - - - - 0 0 0/0 - 12 VTY - - - - - 0 0 0/0 - 13 VTY - - - - - 0 0 0/0 - 14 VTY - - - - - 0 0 0/0 -
My config is extremely basic however from what I can tell it should work
Router#sh ru Building configuration...
Current configuration : 525 bytes ! version 12.1 no service single-slot-reload-enable service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname Router ! ! ! ! ! ! ip subnet-zero ip host R1 2001 100.1.1.1 ! ! ! ! interface Loopback0 ip address 100.1.1.1 255.255.255.255 ! interface Ethernet0 no ip address shutdown ! interface Serial0 no ip address shutdown ! interface Serial1 no ip address shutdown ! ip classless ip http server ! ! line con 0 line 1 8 transport input all line aux 0 line vty 0 4 ! end
Where Do I go from here?
Looks like I resolved it, believe it or not the cable ends where not labeled correctly. After a LOT or trial and error they are now correct and everything is working.
