Problem block pix501
Jul 01, 2006 1 Replies
hello
I have a problem with pix 501, i have two vpn, with two sites, the vpn work ok, the problem is the pix, the pix block, the led to connect the pix to hub blink ver fast, i tray to telnet of pix not responde, i solve the proble to power off a hub a power on de hub, and work ok
the configuratio es adsl-pix501-hub 8 puertos 4computer 1printer
paste the configuratio pix to solve the proble
thank
: Saved : Written by enable_15 at 07:11:05.615 UTC Wed Jun 14 2006 PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname hotelavi domain-name ciscopix.com no fixup protocol dns fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol ils 389 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 no fixup protocol tftp 69 names
access-list outside_cryptomap_20 permit ip 192.168.0.0 255.255.255.0
192.168.10.0 255.255.255.0 access-list outside_crip1 permit ip 192.168.0.0 255.255.255.0 210.210.210.0
255.255.255.0
access-list 101 permit ip 192.168.0.0 255.255.255.0 192.168.10.0
255.255.255.0 access-list 101 permit ip 192.168.0.0 255.255.255.0 210.210.210.0
255.255.255.0 pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside 172.26.0.5 255.255.255.0 ip address inside 192.168.0.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 101 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 172.26.0.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 192.168.0.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto map outside_map 20 ipsec-isakmp crypto map outside_map 20 match address outside_cryptomap_20 crypto map outside_map 20 set peer 110.110.11.10 crypto map outside_map 20 set transform-set ESP-3DES-MD5 crypto map outside_map 30 ipsec-isakmp crypto map outside_map 30 match address outside_crip1 crypto map outside_map 30 set peer 110.120.31.95 crypto map outside_map 30 set transform-set ESP-3DES-MD5 crypto map outside_map interface outside isakmp enable outside isakmp key ******** address 110.110.11.10 netmask 255.255.255.255 no-xauth no-config-mode isakmp key ******** address 110.120.31.95 netmask 255.255.255.255 no-xauth no-config-mode isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 isakmp policy 30 authentication pre-share isakmp policy 30 encryption des isakmp policy 30 hash sha isakmp policy 30 group 1 isakmp policy 30 lifetime 86400 telnet 192.168.0.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 terminal width 80 Cryptochecksum:53e12eaae5923e91b78776c6ca5b8516
You may wish to investigate Cisco PIX Hardware Troubleshooting:
Sincerely,
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant Website:
