Cisco 500 CS problem
Feb 05, 2006 5 Replies
Jump to replies (5)
Guys, This 500 cs is killing me. ports 1-8 are fine...ports 9 - 16 i can see the output once I am reverse telnet but nothing happens when i type. I have read all the message boards and some say to have no exec while others say enable it. It make no difference in this case as I have tried it both ways. Is it possible I have a bad set of ports. I have taken the case off etc but to no avail Please help. I have attached the config below
access-server#show config Using 1869 out of 32512 bytes ! ! Last configuration change at 23:24:19 CST Sat Feb 4 2006 ! NVRAM config last updated at 01:56:38 CST Sun Feb 5 2006 ! version 10.3 no service pad service password-encryption service udp-small-servers service tcp-small-servers ! hostname access-server ! clock timezone CST -6 clock summer-time CST recurring ! ip routing ! interface Loopback0 ip address 11.0.0.1 255.255.255.255 ! interface Ethernet0 ip address 192.168.0.4 255.255.255.0 ! router eigrp 100 network 192.168.0.0 ! ! ip host r1 2002 11.0.0.1 ip host r2 2003 11.0.0.1 ip host r3 2004 11.0.0.1 ip host R4 2005 11.0.0.1 ip host r5 2006 11.0.0.1 ip host r6 2007 11.0.0.1 ip host bb1 2009 11.0.0.1 ip host c3550 2008 11.0.0.1 ip route 0.0.0.0 0.0.0.0 192.168.0.1 ! menu CCIE2B text 1 R1 - 2503 menu CCIE2B command 1 telnet r1 menu CCIE2B text 2 R2 - 2504 menu CCIE2B command 2 telnet r2 menu CCIE2B text 3 R3 - 2520 menu CCIE2B command 3 telnet r3 menu CCIE2B text 4 R4 - 2612 menu CCIE2B command 4 telnet r4 menu CCIE2B text 5 R5 - 2612 menu CCIE2B command 5 telnet r5 menu CCIE2B text 6 R6 - 3640 menu CCIE2B command 6 telnet r6 menu CCIE2B text 7 S1 - C3550 menu CCIE2B command 7 telnet bb1 menu CCIE2B text 8 BB1 - C2521 menu CCIE2B text 16 Display Current Terminal Server Connections menu CCIE2B command 16 sh sessions menu CCIE2B text 17 Disconect Current Terminal Server connections menu CCIE2B command 17 disconnect menu CCIE2B text 18 Return to CLI menu CCIE2B command 18 menu-exit alias exec ss show session alias exec src show running-config ! line con 0 line 1 transport input all line 2 16 no exec transport input all line vty 0 4 login ! ntp clock-period 17301766 ntp master ntp server X>X>X>X end
access-server#
What does the output of say show line 9 display on the access server?
What does show line for the console of the device it is connectred show ?
Here's the output after trying to reverse telnet:
access-server#r1 Trying r1 (11.0.0.1, 2002)... Open
Rack1R1# access-server#bb1 Trying bb1 (11.0.0.1, 2009)... Open
00:11:00: %LINK-5-CHANGED: Interface Async4, changed state to reset 00:11:05: %LINK-3-UPDOWN: Interface Async4, changed state to up ( I can see the output i just can't type anything)
access-server#show line 2(working connection) Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
  • 2 TTY 9600/9600 - - - - - 1 0 0/0
Line 2, Location: "", Type: "" Length: 24 lines, Width: 80 columns Baud rate (TX/RX) is 9600/9600, no parity, 2 stopbits, 8 databits Status: Ready, Connected, Active Capabilities: EXEC Suppressed Modem state: Ready Special Chars: Escape Hold Stop Start Disconnect Activation ^^x none - - none Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch 0:10:00 never none not set Session limit is not set. Time since activation: never Editing is enabled. History is enabled, history size is 10. Full user help is disabled Allowed transports are lat telnet rlogin mop. Preferred is lat. No output characters are padded No special data dispatching characters Modem hardware state: CTS* DSR DTR RTS Group codes: 0 access-server# ! access-server# show line 9(non-working) Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
  • 9 TTY 9600/9600 - - - - - 1 3 0/0
Line 9, Location: "", Type: "" Length: 24 lines, Width: 80 columns Baud rate (TX/RX) is 9600/9600, no parity, 2 stopbits, 8 databits Status: Ready, Connected, Active Capabilities: EXEC Suppressed Modem state: Ready Special Chars: Escape Hold Stop Start Disconnect Activation ^^x none - - none Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch 0:10:00 never none not set Session limit is not set. Time since activation: 0:02:33 Editing is enabled. History is enabled, history size is 10. Full user help is disabled Allowed transports are lat telnet rlogin mop. Preferred is lat. No output characters are padded No special data dispatching characters Modem hardware state: CTS* DSR* DTR RTS Group codes: 0 access-server#
If you connect line 9 to where line 2 is currently connected, does the problem follow ?
Yes, the problem seems to be with the ports 9 - 16. The weird part is I can see the output. I even changed cables connected to the port on diff. devices.
It is quite possible that port 9-16 are supported by a different set of interface electronics. The transmit side may be faulty.
