Hallo,
I have probably a very simple question, but... I configured this pix
501 for remote pptp connection with local authentication. Once the user is connected he should only be able to make a connection to a inside host on port 3200. I know that this is possible if i configure the authentication via radius and create a windows group with port filtering, but i want to be able to manage all this on the firewall. Can anyone tell me how to do this, i've already tried with access-list on the inside interface but with no result. Hereby my running config:
PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password encrypted passwd encrypted hostname ORDLEUVENPIX02 domain-name ordina.be fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list nonat permit ip pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside ip address inside ip audit info action alarm ip audit attack action alarm ip local pool client_vpn_pool pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0 0 access-group outside in interface outside route outside 0.0.0.0 0.0.0.0 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-pptp telnet timeout 5 ssh timeout 60 console timeout 0 vpdn group 1 accept dialin pptp vpdn group 1 ppp authentication mschap vpdn group 1 ppp encryption mppe 128 vpdn group 1 client configuration address local client_vpn_pool vpdn group 1 pptp echo 60 vpdn group 1 client authentication local vpdn username test password ********* vpdn enable outside terminal width 80
greetz,
