Clueless needs Cisco 2801 Nat help
Dec 26, 2006 3 Replies
Jump to replies (3)
Kinda thrown into administration of a cisco 2801 router and am really not sure what to do about an issue we have. Below are the relevant parts of our config with IP's changed. The issue is, with this config, we are natting all internal IP's going to the Internet as a single IP (PAT?)...same IP as the external interface. The issue this is causing are bounced emails sent to domains who are doing reverse lookups...our mail server was assigned the 65.199.20.20 address and receiving mail to that address is no problem. But when sending, the IP in the mail header is the Serial interface IP. How do I make the mail server IP the same for incoming and outgoing? Do I need a nat pool?
interface FastEthernet0/0 description Connection to Pix bandwidth 1544 ip address 192.168.70.2 255.255.255.240 ip nat inside speed 100 full-duplex no cdp enable ! interface Serial0/1/0 description Verizon MCI no ip address encapsulation frame-relay IETF no fair-queue service-module t1 timeslots 1-24 frame-relay lmi-type ansi ! interface Serial0/1/0.500 point-to-point ip address 63.81.10.10 255.255.255.252 ip nat outside frame-relay interface-dlci 500 ! ip classless ip route 0.0.0.0 0.0.0.0 Serial0/1/0.500 ! no ip http server ip nat inside source list 7 interface Serial0/1/0.500 overload ip nat inside source list 8 interface Serial0/1/0.500 overload ip nat inside source list 9 interface Serial0/1/0.500 overload ip nat inside source static tcp 192.168.70.6 25 65.199.20.20 25 extendable ip nat inside source static tcp 192.168.70.7 80 65.199.20.20 80 extendable ip nat inside source static 192.168.70.5 65.199.20.20 ! logging history alerts access-list 7 permit 192.168.50.0 0.0.0.255 access-list 8 permit 10.0.0.0 0.0.0.255 access-list 9 permit 192.168.70.0 0.0.0.255
The issue that you have is that the the wrong nat statement is grabbing and natting your outbound traffic. As far as I know the order of net statement's evaluation is not specified.
What you need to do is to force the correct nat statement to be used with access lists.
You don't say precisely enough what you want to be sure but I think you need to move to Extended access-lists.
Here is what I would put.
Access-l 7, 8, and 9 can be combined, lets do that too. Also I now always use names access-lists were possible.
! You want to end up with:- ip nat inside source list ACL.nat interface Serial0/1/0.500 overload ip nat inside source static tcp 192.168.70.6 25 65.199.20.20 25 extendable ip nat inside source static tcp 192.168.70.7 80 65.199.20.20 80 extendable ip nat inside source static 192.168.70.5 65.199.20.20
ip access-l extended ACL.nat deny 192.168.70.6 any eq 25 ! < -- Outbound smtp permit 192.168.50.0 0.0.0.255 any permit 192.168.70.0 0.0.0.255 any permit 10.0.0.0 0.0.0.255 any
! You need to remove the unwanted statements
no ip nat inside source list 7 interface Serial0/1/0.500 overload no ip nat inside source list 8 interface Serial0/1/0.500 overload no ip nat inside source list 9 interface Serial0/1/0.500 overload no access-list 7 no access-list 8 no access-list 9
All the Cisco examples call an an ACL like this "nonat" but that just makes my head hurt.
This config will still leave all other traffic from your mail server, and other servers too, overload NATted to the outside address.
show ip nat translations ! to see what is going on. clear ip nat tr * ! to get rid of old rubbish (and kill existing sessions)
Sorry...this is a typo...should be as follows...
Forget this post...figured out what I was doing wrong. Just took out the port 25 static and made it a full static nat and the issue is resolved.
